I wonder if a good surge protector would help and just keep the mobile connector plugged in? I mean we don't run around the house and unplug all appliances and devices while we're away. They don't cost 100k either though I do leave mine plugged in during storms since my chargepoint is a smart charger and has gfci protection.I suggest you turn off Sentry Mode at your home location, otherwise you will be using 7% of the battery each day. I don't leave my Tesla Model Y plugged in when I am away. In the spring and summer months there are frequent electrical storms. The risk is small but the potential amount of damage is high if the Tesla vehicle is plugged in and there is a close by lightning strike.
I always unplug the expensive electronics in my home whenever I am away or during a storm. A surge protector may help but would not stop the voltage surge of a ground lightning strike coming through the power line or ground connection. That amount of energy would overwhelm any surge protector.I wonder if a good surge protector would help and just keep the mobile connector plugged in? I mean we don't run around the house and unplug all appliances and devices while we're away. They don't cost 100k either though
Glad nobody was on the poddy at the timeI always unplug the expensive electronics in my home whenever I am away or during a storm. A surge protector may help but would not stop the voltage surge of a ground lightning strike coming through the power line or ground connection. That amount of energy would overwhelm any surge protector.
Lightning hit the septic tank of this home in Florida: Lightning strike causes Florida home's toilet to explode
Nope.I wonder if a good surge protector would help and just keep the mobile connector plugged in? I mean we don't run around the house and unplug all appliances and devices while we're away. They don't cost 100k either though I do leave mine plugged in during storms since my chargepoint is a smart charger and has gfci protection.
That was just god telling you it was time for a Tesla. I had a 2012 volt man what a nice car those were.Nope.
I had my Chevy Volt plugged in at my landlords business (next door to the house I was renting) until I could get an outdoor outlet installed. There was a "bolt from the blue" lightning strike (no rain, blue sky sunny summer day) on the landlords business. The Volt was totaled... dealership kept trying to repair it for a while but after replacing several computer modules at a crap load of $$$ each they gave up and the insurance company totaled it out. The stock EVSE itself for the Volt had fusible links, the car charging system had fusible links, the computer systems had fuses... lightning that has bridged the gap from several hundred (sometimes thousands) of feet in the air to the ground don't give a flip about the fraction of an inch gap provided by a fuse or fusible link.
Later,
Keith
This happened back in 2016, before the model 3 came out... and Model S was out of my price range. I replaced the first Volt with a 2016 Volt, and then traded that in on a 2017 Bolt when it became available.That was just god telling you it was time for a Tesla. I had a 2012 volt man what a nice car those were.
They really overdelivered in my opinion it felt well above its price point. I'm not to concerned if it happens it happens I'm not running to the garage anytime it's raining and unplugging it.
Fully charge it. Then leave it unplugged. It almost never happens. But batteries tend to create fires most often when charging.I plan to leave my MYLR plugged in to my garage wall charger for about 6 weeks while I am out of town.
Re: #2, With the features noted in #3 turned off the OP won't need to leave the Tesla Model Y plugged in when parked for 6 weeks. The high voltage battery would lose just 1% to 2% per week if left this way.My advice:
- Set the desired SOC to 50% (best for Lithium battery storage)
- Plug in the car!
- Turn off Sentry, Summons and overheat protection
- Don’t keep checking the car via the Tesla app!
- And if you can, put a battery tender on the 12V battery. This will keep it from cycling.
It is 0.5-1% / day, not per week! In my MS I have confirmed it as 500 watts per day for my car.Re: #2, With the features noted in #3 turned off the OP won't need to leave the Tesla Model Y plugged in when parked for 6 weeks. The high voltage battery would lose just 1% to 2% per week if left this way.
Re: #5, Lithium batteries don't require a float charge. (For long term storage 12V lead-acid batteries can be maintained with a float charge.) A lithium battery should not be maintained at 100% state of charge (SOC),
When I left my 2020 LRMY parked, unplugged, unlocked inside my home garage for a week with Sentry mode turned off the battery SOC dropped 1%. Perhaps others can provide their experience.It is 0.5-1% / day, not per week! In my MS I have confirmed it as 500 watts per day for my car.
