Thank you! By "plug" you mean the NEMA 15-50 connector right?
That makes sense, thanks!
Just to make sure I understand the terms in this option:
- Install a dryer type outlet in the garage -> attach the NEMA 14-50 "adaptor" to that outlet, and then attach the J1772 from the NEMA to the car?
Is the NEMA 14-50 referred to as an "adaptor" or a "plug"?
Is the J1772 referred to as a "mobile connector" an "adaptor" or a "charger"?
When looking at the forums these different terms are used, but I am unsure what they are specifically referring to?
A dryer-type receptacle (outlet) is for a 240V, 30 amp circuit. The current plug and receptacle used with the home electric clothes dryer is the 14-30. Older dryer receptacles include the 10-30 (found in older homes.)
The 14-50 receptacle (rated for 240V and up to 50 amps), in addition to EV charging, is used with RV motor homes and in the kitchen with electric stove/ovens.
You don't need the J1772 adapter when using the Tesla Mobile Connector or Wall Connector (the J1772 adapter is only used with a third-party (not Tesla) Level 1 or most often Level 2 charging stations. When using Electrify America or one of the other DC Fast Charge network charging stations you would need to use the Tesla CCS1 adapter (available from the Tesla store for $250.) You don't need an adapter to use the Tesla Supercharger network.
The cost of installing a new 14-50 receptacle for EV charging now must include a GFCI 50A circuit breaker (about $100.) A quality 14-50 receptacle from Hubbell, Bryant or Cooper (costs around $80). The cost equation now favors installing the Wall Connector over installing a new 14-50 receptacle.
Tesla Charging equipment recent pricing history: The Tesla Gen2 Mobile Connector used to come with the Tesla vehicle at no cost but now costs $230 additional (up from $200.) The Tesla Gen3 Wall connector used to cost $500, then $550 and now costs just $400.
You might want the Wall Connector if any of the following apply to your home charging:
You want to be able to charge at 240 volts and either 40 amps or 48 amp charging rate (Charging at 48 amps requires the Wall Connector. Charging at 40 amps requires either the Wall Connector or the rarely available for purchase Tesla Corded Mobile Connector. Third-party charging stations that enable charging at 40 amps are available at higher cost than the Tesla Corded Mobile Connector.)
You plan to install the Tesla charging equipment outside where it is exposed to the weather.
You value having a 24 foot long charging cord versus 18.5 feet for the Mobile Connector (not including the plug and electronics chassis.)
You might someday have a second EV and want a second charging station that can take advantage of automatic load balancing while charging (when two or more Wall Connectors are installed.)
You value being able to lock out unauthorized Tesla vehicles from charging. (You can set the Wall Connector to only allow Tesla vehicles with an authorized VIN to be able to charge.)
