I am in the Bay Area of Northern California, in PG&E territory.
Tesla recently completed the site assessment for my solar + whole-home backup PW install and, despite my indicated preference for a garage installation, and prior discussions with my Tesla advisor about it, Tesla has provided a plan set with all equipment being mounted on an outside wall (a side wall) adjacent to the service meter (which is outside, on the same wall) and behind the fenced-in portion of that wall (a detail called-out in the plans).
When I questioned my Tesla advisor about why the plan set doesn't reflect the requested garage installation, he seemed to imply that something in my jurisdiction might be preventing it.
But... I have been in contact (at length) with my local city and fire officials (well before the site assessment) and have confirmed and re-confirmed that there should be no issues with a garage installation, provided that a hard-wired, interconnected heat detector is installed. (This is the only requirement currently unmet; all other requirements are already met.)
I discussed the idea that I would have the required heat detector installed with my Tesla advisor (again, well before the site assessment).
I can also provide up to 26' of uninterrupted wall space inside the garage, which is more than enough for the desired PWs (even with theridiculous 3' spacing currently required by my jurisdiction) and which I believe the site assessors observed. I also mentioned this to my advisor early on, and to the assessors during their visit.
Now, I do currently have a tool pegboard and some minor shelving mounted on the target wall. Is Tesla so "unreasonable" in their site assessment that they don't account for the fact that I would, of course, remove those things prior to installation? Is this issue potentially as mind-numbingly dumb as, "yeah, we saw some stuff on the wall, so no garage install"?
If not that, then does anyone see something in the proposed system diagram below to indicate that all the new equipment CAN ONLY be installed outside, next to the existing meter and main breaker?
The one potential caveat being that the existing meter and main breaker are on the opposite side of the house from the garage (and distribution panel). Even with this caveat, can anybody suggest a reason why the new equipment CANNOT be located inside the garage?
In my view, Tesla could just as easily tap into the main service lines inside the garage (just before they reach the distribution panel) as they could outside (just as they leave the main breaker), no? In both cases, the system diagram would look identical.
The plans also call for an "emergency stop" switch to be installed outside (near the meter), feeding a 12V stop signal to the PWs. But, that would only be a matter of a bit more conduit/wiring, if the PWs were inside the garage, right? (Btw, I'm not certain why the stop signal is not shown connecting to all four PWs in the diagram; only two. Mistake?)
