Cost to dip my Model S Burnt Copper
$165 for 3 gallons of black PDS for the base - used 2.5 gallons
$320 for 4 gallons of DipPearl Topcoat -used all 4 gallons
$56 for 4-25 gram bags of Burnt Copper Alloy Pearl
Roughly $30-40 in prepping materials
-Layed the black base
-Mixed all Burnt Copper Pearl into 2 gallons of Topcoat, sprayed that
-Layed the other 2 gallons of Topcoat for a glossy finish
Dipped by yours truly
Kushari stopped after step 2 i think. Spraying the pearl mixed into Topcoat is what gives the satin finish. So it shows it'll costs more $ the glossier you want it.
- - - Updated - - -
It's supposed to last about 2 years. DipYourCar has done a lot of long term testing on their products before release. There are a lot of testimonials out there showing its endurance. Why keep a car dipped very long when u can change it to a different color in one day?
It took my about 20 minutes to peel the copper from my car. As u can see each panel came off in one big sheet. The thicker u lay it, the easier it is to peel. To be honest, if someone doesn't do their research and know how much dip to put on they deserve the hassle of spending 15 hours peeling a car instead of 30 minutes. A lot of testing should be done before someone decides to dip their car. Obviously. As for overspray, masking is the solution. Some pieces like the door handles I didn't mask off before spraying. I just made sure to lay enough product there so that when I was done I knew it would peel. The gap between the door handle and the body created a break in the dip allowing me to peel it without affecting the rest of the door.
