You get info about correct answers with short briefs when done, if selecting ”Show Result” (or similar text.What are the answers?
There's often an engineering tension between these two. Degradation from time and cycles, and high energy density. High energy density means lots of molecules with high potential energy and stuffing ions into small atomic holes. Stuffing the materials tightly degrades them structurally, and the molecules like to have side reactions which over time reduce capacity. Any reactions other than the primary energy transporting one, fully reversible, inevitably loses capacity as the molecules turn into something other than what they were originally intended to. Batteries are complex chemical soups and sandwiches of complex stuff.As technology in this area is advancing rapidly, hopefully this will be a thing of the past. Imagine an EV battery pack that doesn't degrade due to time, along with a minimum 500 miles of range. When that happens there will be a lot more ICE vehicle lovers joining our team.
I think the present 4680 is NMC chemistry, which explains the lower energy density.If it were to work, the energy density would jump up substantially, but it hasn't, the Tesla 4680s are lower energy density than the Panasonic 2170 packs.
I agree, and it also implies there is no high end heavy-silicon anode which would have increased energy density even more to compensate.I think the present 4680 is NMC chemistry, which explains the lower energy density.
I think the LG NMC cells are very good in terms of degradation, in general lower than Panasonic NCA cells.I agree, and it also implies there is no high end heavy-silicon anode which would have increased energy density even more to compensate.
It appears Panasonic has some proprietary tech to let them use NCA well (low degradation) when nobody else can.
There are no good free ones.On a side note, what’s a good free iPhone tesla 3rd party app? Tessie is great but I don’t find I use anything other than the Usable capacity metric (which may be useless…) and scanmyTesla is only for Android?
Note that your initial capacity was above about 80.6kWh or 80.7kWh to display 315 miles. I believe this is the case in Canada (don’t get the “LGView attachment 942890
Just passed 2000 kms on my April 10th build M3p, charged to 55% since delivery.
Too early to tell but looking good…
Scan My Tesla is for iPhone as well.On a side note, what’s a good free iPhone tesla 3rd party app? Tessie is great but I don’t find I use anything other than the Usable capacity metric (which may be useless…) and scanmyTesla is only for Android?
Thats right, the LG 78.8 kWh pack usually tops out just north of 79, 79.1-79.2 or so.Note that your initial capacity was above about 80.6kWh or 80.7kWh to display 315 miles. I believe this is the case in Canada (don’t get the “LGspecial” packs), anyway.
Assuming that 315 miles is the advertised value for initial range in Canada, set your start capacity to 80.7kWh in Tessie.
Regardless, you are doing fine. If you charge to 100% and you show 315 you are doing even better than the Tessie estimate.
I’m not following with the 80.7 - Tessie is predicting 506kms (315 miles) but I can check the estimate on screen when I charge to 100% for a road trip.Note that your initial capacity was above about 80.6kWh or 80.7kWh to display 315 miles. I believe this is the case in Canada (don’t get the “LGspecial” packs), anyway.
What’s the significance of the 80.7 here? The highest usable capacity I’ve seen since I got it is 80.4 (Tessie).
Great info - thank you!The 80.7kWh (or 80.6kWh - I defer to others on the precise value) is your starting capacity.
If you don’t have that (approximately), you don’t have 315 miles at 100%.
You are fairly close right now so you might well get to 315 at 100% (can use the energy screen method at that point and you’ll get 80.6kWh or so).
Anyway you should change the initial capacity (78.8kWh) in Tessie (press and hold or some such) so that it is correct.
I have no idea why Tessie thinks 80.1kWh will give you 315 miles - it won’t of course. (More like 313 or so.)
This stuff is all very deterministic.
The displayed range is static so the displayed range will not change from lighter wheels etc. It might change if you change the wheels in the menua to 18” or 19”, but this of course do not change the real range.Great info - thank you!
I am also planning on swapping out the Ubers for 19lb Enkeis so ideally should see more than 315…
Agreed! the trade off of increased handling, performance, and better stopping distance, is well worth the minor decrease in range.I guess I am trying to decrease my wh/km with the 18” wheels (I was planning on changing it within the menu as well to account for speedometer/regen changes).
Tires are a tricky one since the p-zero elects are EV-specific 20” and I am replacing them with Michelin/Continental performance tires 18”. I wanted to go with Primacy/low rolling resistance but these performance tires are just too good when handling!!
