On the topic of age degradation, though, is there any data in actual Tesla cars? Fully accept the data from
@AAKEE, but will that be different in a pack of >thousand batteries with BMS thermal and level management as opposed to individual cells?
Well, yes.
To start with, the BMS can not do very much except from keeping the cells in balance when needed, cool or heat the battery during drives (which happens quite seldom). Other from that it can almost only sit there and watch the cells get old.
It (the BMS) do not have the authority to use a lot of energy to keep the pack cold in hot days (except for that, it would be very expensive).
It (still, the BMS) doesn’t even have the authority to decide what SOC to charge to.
It can only watch the owner deciding to charge to XY % whenever the owner wants to.
The cells age from calendar aging from [Time x SOC x Temperature]
Each three of these will set the pace, and no actions from the BMS can change it.
The fact that it is not lonely cells but in series of 96 and 46 in parallel (3/Y LR packs) do not change the situation for the respective cell.
The normal Tesla never actively heat the cells unless: below about freezing or ~3 degrees Celcius when starting a drive.
Preconditioning is about the same. Not much, just up to about 5C or so. About the same for home AC charging, the battery is heated to about 7-10C if it is colder.
Heating is also done before / during supercharging.
For normal driving the battery heats itself and also is heated by the motors waste heat.
When parked, not driving the battery will not be heated/cooled.
As we drive in average maybe < 1 hour each day and charge 1-4 hours, about 20 hours each day is not heated or cooled.
Well, I had done a lot of research reading research reports before I got my M3P, almost 3 years ago.
I did calculate how the degradation would be for my car. I did see slightly less degradation than my calc’s told me.
After having had the car for almost 1 year, I could adjust the calculation because my logs showed me the average cell temp was a bit lower than my initial estimation.
After this adjustment, the calculation and the actual degradation followed very precisely for the rest of the time I had the car. ( Initially I planned to stay with it for quite long, as I usually do but I suddenly had the opportunity to get a M S Plaid and that overtook the idea to proof my case with the M3P low degradation. I tried to conact the new owner, but no joy so far. He doesnt seem to even return messages).
I have constructed formulas for calculating the capacity of Teslas with NCA batteries and it so far match the cars quite well.
The indatas are the most uncertain points, but still mostly really good matches.
I have quite a batch of friends and ex collegues that have model 3s and Ys.
Most of them follow the low SOC line and all that do has low degradation. There is no exceptions from that.
I had 492 km range at the last full charge, and the average for that car M3P ’21 had about 460-465 km range at the same ODO.
For my new Model S Plaid it is a bit early after 4 months, but looking good so far.
The reason I ask is that data shows something like a 2-3% degradation difference in 10 months above 55% SOC at 25C, with a trend of less degradation at lower temps and over time.
The calendar aging reduces with the square root of time.
Reducing the calendar aging by half, means you will have the half degradation after one and five years as well.
Also, I note that in order to measure the charge, a DVA technique was used, then the same cells were recharged to SoC level and put back in storage and re-measured for the longer calendar points. This could add uncertainty to the data. A better technique would be to only measure each cell once only, with some kept unmeasured till the longer time had elapsed.
No, it do not add uncertainty.
You charge snd discharge your car almost any day, so that is not an issue.
They store the battery at tge specified SOC, then cycled it a few times to ”wake it up” and then they measure the capacity, after that they put them back to the storage SOC.
There is some tests that check for the difference by having some extra ”untouched cells” that I have read.
I also did the same with some of my cells, I did skip the ”two months checkup” on a few of them, and at the next checkup there was no difference between the ones that had the checkup and the ones that didnt.
