Hi Fellow Model S owners,
Ive been a member of this forum for almost a year now but mostly a reader and haven't contributed nor posted any thread before.
Today i feel that i need to post this for all owners running spacers on their model S, 21” rims in particular as this is what i have.
I own a 2013 P85 running 21” wheel non-staggered. Bought a set of 19mm spacers to fit in May 2018. Spacers where installed and torqued properly mid Jun 2018.
Today early morning ive noticed a weird noise, metalic scrapping, from the rear left wheel so i pulled over and inspected the car but found nothing to report. On my second drive i noticed the sound had become more pronounced, so again i pulled over and tried to shake the wheel and thats when a lug nut fall on the ground. Lucky enough i was less than 10 minutes away from a tire shop, took off both rear wheels to find out that the spacer studs are snapped
As you can clearly see the rear left spacer has one stud broken and resting within the lug nut. Right side had 3 studs broken as we removed the lug nuts.
Now this is my daily car that i drive atleast 150-200km a day with my family inside. I cant imaging what wouldve happened if i lost more studs and wheel came off. I am glade that i noticed it early enough to prevent and harmful damage.
I have sent the manufacturer an email, and i will not disclose their name yet as i will give them the chance to justify/explain the reason for such issue to happen. But the main purpose of this thread is for all owners with spacers to check their setup thoroughly and periodically as this is extremely dangerous.
