I'm a new owner of a P85D with the 21-inch turbine wheels in 8.5" width at all four corners. I've been contemplating either adding spacers to get a more flushed appearance or new wheels with 20-something offset to do the same. When looking at the side-body contour after the wheel arches, I noticed that the sunken wheels/tires are pretty flushed to the lower rocker body so that any debris or rain being kicked up from the tires will only end up in the wheel well and not at the body. If you flush out your wheels to the top fender, your wheel/tires are now extended past the bottom rocker panels wherein you can potentially kick up debris/rocks and/or rain/mud onto the body and maybe even to rear flared fenders. Not sure how much mud guards will even help here.
My questions is do you just not care, avoid driving in any area with dirt/debris/loose gravel, avoid driving in the rain, or just PPF the crap outta the bottom half of the side of the car?
Hope I'm making sense. I'm hesitant to get spacers or new wheels and just keeping the turbine wheels sunken into the wheel wells for this purpose alone. Plus, I'm starting to get used to the look of the wheels a bit sunken in. Perhaps even gaining some aerodynamic gains?
Here's a pic of the rear. Notice where the red lines show how debris can be kicked up by the wheel and hit the body (imagine the same for the front tires):
