StealthP3D
I'd like to add that on dry roads and wet roads, the Sottozeros are dramatically better than the X-Ice. I actually think the Sottozeros stop and handle better in dry and wet conditions than the stock Michelin Primacy MXM4s.
I agree and that's exactly why I like the Sottozero's so much! They are more than adequate on treacherous snow and ice surfaces yet they totally excel in terms of sporty driving on bare pavement, especially if it's cold and wet. Steering response is crisp and precise, even for a non-winter tire and the ride is quiet and civilized.
Also, I found that 39 PSI works best with the Sottozeros on my car and I like 42 PSI on the stock MXM4s. I don't know if it's the difference in size or tire construction, but 39 just seems to have the best handling and ride balance.
Are using the built-in TPMS to judge pressures or an accurate stand-alone tire gauge? The built-in system is consistent and fairly accurate (at least on our two Model 3's) with the exception that they read lower pressure than actual at altitudes above sea-level. This is because the actual tire pressure is the difference between atmospheric pressure and the pressure inside the tire but the TPMS has no way to compare the pressure to the atmospheric pressure so they simply use a fixed standard value. That's why the TPMS reads low at higher altitudes.
I'm thinking you might live at altitude and thus are running pressures a bit higher than you are reporting. I arrive at my preferred pressures by driving the car hundreds of miles under various conditions and paying particular attention to how "glued to the road" it feels when cornering near the limits of traction. At pressures below 44 psi cold I find the Sottozero 2s cannot handle as many corner G's without starting to release early. The optimum pressure will be slightly lower with a completely empty car (I do my testing with about 400 lbs. of people and luggage). The pressure for optimum straight line stopping distance and acceleration is likely slightly lower than for optimum corner grip. In warmer weather the optimum pressure is also lower because the tire builds more heat (and thus natural temperature induced pressure rise) than in cold weather.
Little known fact: When testing for optimum pressures it is necessary to let the tread wear to the new pressure before drawing conclusions. This is because the tread wears into whatever pressure you are running at. Whenever the pressure has been adjusted up or down more than a pound or two, the traction will be less for a couple hundred miles (until the tread wears into the new pressure).
