SomeJoe7777
Marginally-Known Member
I'll supply some interesting data points here. I experienced this exact issue as well, with a few differences that I'll explain.
TPMS Type (Winter): Autel Sensor-1, fully Tesla compatible, not cloned, new IDs generated
TPMS Reset Prompt: Yes, "New sensors detected / Select wheel size", then "Reset Successful"
TPMS Pressure Status: 42 psi
Delivered Wheel Size: 19" Sport + Continental ProContact RX 235/40R19
Winter Wheel Size: 18" Aero
Winter Tire Type: Nokian WRG4 235/45R18
Model 3: LR RWD
Temperature: Fully warm, no limited regen dots
Regen Status: Limited regen at high speeds, nearly normal regen kicks in at around 30-25 MPH. The most noticable speed range where regen was limited was 40-30 MPH. I never experienced no regen, but the limitation I saw was about half of normal. This occurred for the first 200-300 miles of driving on the WRG4's. After that, the regen slowly returned to normal and is now nearly fully normal after 500 miles of driving.
Points of interest:
To supply additional data, I have a P3D+ vehicle that I'm about to swap to a set of all-weather tires. In this case, they will be the Vredestein Quatrac 5's on T-Sportline 18" wheels. I will report here what those behave like when I get them installed. The Vredestein is very similar to the Nokian WRG4 - it's an all-weather tire with the 3-peak mountain/snow symbol, but can be run year-round. The tire is the same size as the Nokian (235/45R18).
If we are correct that this issue affects RWD cars only, then I will have a good data point to compare, since both of my Model 3's are being driven in the same temperatures and conditions.
Model 3: LR RWD
Points of interest:
- The all-weather Nokian WRG4 tires are most certainly a tire that will exhibit this problem, although perhaps to a lesser degree than dedicated winter tires..
- Like others, my regen was limited at high and medium speeds, then will "grab" at lower speeds. In my case, the point where it begins to feel normal was between 30-25 MPH.
- My regen was never a "no regen" case, it was only limited. Typical response at the higher speeds was about 1/2 of normal regen.
- I am using Tesla Aero rims.
- I don't feel that TPMS has anything to do with this issue.
- I do feel that this issue may be isolated to RWD vehicles.
- I feel that the tread release compound on brand new tires contributes to the problem. The break-in period for new tires to remove this tread release compound is around 300-500 miles.
- My regen slowly returned to nearly normal after 500 miles of driving, which is enough time for the tread release compound to break down and disappear.
- I am in the Southern US, temperatures here have been very mild, nothing below 60F. (I put these winter tires on early for other unrelated reasons. Please, no comments along the lines of "why are you using winter tires in the southern US?" Answer: Because I want to. )
- This is not a v9 software issue -- most of my data here was gathered under 2018.36.2, which is the final v8 software.
