idoco
Another concern I have is my roof is roughly 15 years old and it's still in pretty good condition. I wonder if I'd be recommended to have a new roof installed prior to getting solar panels installed? That'd easily be an extra $8K that would be pretty hard for me to swallow.
This is exactly what we did. I knew the roof would need replacement so I ended up putting a metal roof on under the panels. The company that did our install was a roofing company for over thirty years before they added solar services. One of the reasons I chose them.
As others have mentioned the roofing may be eligible as part of the solar installation. You'll need to check state and federal law.
As for battery backup, our batteries are in lieu of a generator. Post Sandy we were off grid on solar and battery for a week while the power lines were being repaired. We have 10.5kW solar with ~40kWh battery backup.
We have lead acid instead of lithium. At the time of installation almost a decade ago lithium batteries were really not an option. Even if I had to replace my batteries today I would probably still go with flooded lead acid. Mainly from the price standpoint.
For the current Powerwall the price is ~$485/kWh (based on $6500 for ~13.5kWh Powerwall). For flooded lead acid, deep cycle batteries that price is ~$145/kWh (based on $375 for a ~2.6kWh battery). So an ~40kWh Powerwall system would cost $19500 vs $5600 for lead acid. Since weight isn't a big issue for stationary backup if you have the room then lead acid may be a good option.*
*Above calculation is simple upfront cost for batteries alone. Depending on actual use and frequent deep discharges this may shorten the life of lead acid batteries relative to a lithium pack and may change the cost ratio from 3:1 to 2:1.
