xpitxbullx
In Las Vegas, it would be insane to test this theory in the summer. I’ll sit back and see how the northern states chime in.
Great live experience information. Thanks.One thing I have noticed with windows down on my Model 3.
There is no wind drumming even when the window is all the way down.
Aero is every good on this car.
AC compressor's effect on consumption in my MS is completely negligible, even with temperatures well north of 100F. In fact, that's often when I see my best efficiency.
It's 2018. There's zero reason to be "that guy" driving around with the windows open on account of "fuel economy" or worrying that your car is going to overheat by the time you get to the top of the hill.
But, whether we care of not, some of us prefer outside air to AC, and live in places where the air is OK, and the temperature is amenable to opening the windows half the time, and given that BEVs have practical refueling limitations, it'd be nice if there were real data for the Model 3.
Excellent info. Thanks.There are so many variables at play on my regular commute, but I typically see about 15-20 wH/MI improvement without AC running. This would be windows open on city roads, and just the fan running while on the highway.
Nice. Very nice post. Thanks for the information.All the windows down. Follow this guy to work all the time Feels like the eye of a hurricane. Everything just stands still.
Fantastic info. Thanks.I have real world data for Model 3. New England here. In the vast majority of situations, windows down is way more efficient, even on the highways. I've actually tested this extensively in various speeds and weather, using the car's efficiency reading as my guide. The following is just for my commute (I've tested on various other recurring trips as well).
Baseline measurement: daily commute is 80mi round trip. First let's look at temperature effects only (HVAC off, windows rolled up). Ideal efficiency happens when temps are between 70-80F. Here, I get around 165Wh/mi for the round trip. The reason for this insanely good efficiency is due to intermittent traffic that keeps my average speed down. If the same commute was performed with no traffic, efficiency would be around 190Wh/mi @ around 70mph. At around 50F, efficiency drops to around 180-190Wh/mi. And at 90F and above, efficiency drops to around 205Wh/mi (I suspect because the A/C compressor kicks on to cool the battery).
Now, with the A/C running for cabin conditioning, and ideal temp range (70-80F), that same round trip jumps to 210Wh/mi. Without A/C is 165Wh/mi. That's a huge penalty. What's worse, the firmware doesn't seem to be smart enough to shut off the A/C if outside temps are already below the set point. In other words, if you set cabin temp to 72, and it's 70 outside, and you put the HVAC settings on Auto, it will still run the A/C, presumably for dehumidifying purposes. In these scenarios, I always set to manual and shut off A/C compressor and just let outside ambient air keep the cabin cool. Running just the HVAC fan uses negligible energy. not enough to show up in measurements.
I've also kept windows down for this same commute, no HVAC, and I average around 170Wh/mi. I have yet to measure the effect of going 70mph the whole way with the windows down. I suspect that will have worse efficiency. But at that speed, I'd likely just crack the window, which would drastically reduce drag. Windows all the way down at highway speeds is not comfortable, and it's really noisy.
Test for yourselves. If you can bear it, given it's the dead of summer and it's hot, turn off the HVAC for any of your drives. You should see a pretty huge increase in efficiency. I haven't found a situation where windows down can cause an equivalent drop in efficiency.
Also FWIW, I grew up in the suburbs of Atlanta GA, so I consider myself very heat tolerant. I also grew up riding in econoboxes with no A/C, so it doesn't faze me at all to test out no A/C in 90+ weather. Kinda nostalgic, actually. Now if only the Model 3 had a choke.
