Couldn't find much on the forums here about this, so maybe it's just my car...but in the last couple weeks, after I place my phone on the left front charging pad of the car, it will continually stop/start charging (i.e., the phone screen wakes up to say it's starting to charge, and then it happens again several seconds later).
Some notes on the behavior:
Car Details:
Phone Details:
I was curious if anybody else might have encountered this? If so, did you eventually find the issue cause, and/or fix it? Thought I'd check this knowledge base before hitting up the service center-
- The behavior happens regardless of where I put the phone on the pad, or if the car is moving or not.
- It seems to happen on and off between different car drives (i.e., it happens constantly on some drives but never on others).
- This only started a few weeks ago; for the year+ prior, it was working fine.
- The behavior does not happen when the phone's on the right front pad...only the left. I thought it could be the phone case I got a month or two back, or maybe updating my phone to iOS 17, or maybe even the Christmas update...but with this, I think there might either a charger failure or something loose?
Car Details:
- 2022 Model S Plaid
- Christmas update
Phone Details:
- iPhone 11
- OS 17.2
