A quick status update:
As you've seen spread across a number of posts, we had reliability problems with early shipments. In reality, we only ever put 3 appliques on cars. Mine, Artsci's and one other (who will remain anonymous so that people waiting won't lynch them). The original design used a board behind each letter. The interconnects between these boards did not hold up to the weather and vibration in a car.
After trying to make the interconnects more reliable, we finally made the decision to switch to one long board that spans all five letters. As of 24 Mar 2015, those have been designed, checked, released to fabrication, built, shipped, and I expect to receive the first batch on Monday 27 Mar 2015. At that time, we'll do the neopixel fabrication, place appliques on the same three cars, and assure that we've solved the reliability problem. I don't have any photos of the new boards yet, so here is a view from the CAD software that we use to design circuit boards:
During this same pause, we took the opportunity to perfect a few things in the system controller and system software:
Hardware wise, we've switched from "screw terminals" to attach the wires to a "molex connector" that's very much like any other connector in your car. A locking plastic plug. The system controller will use the connector shown below; the install kit will contain the matching plastic shell, and crimp-on pins for the ends of the wires.
Also in the hardware, I switched the exact model of processor module I'm using to one that contains a USB connector for code updates. The previous one required a small adapter. We don't plan to ship code updates... but if we do, the connector is there and waiting. Also, this will allow anyone who wants to write their own code for the controller to do so. Of course, this will all be hidden away inside the plastic case. Only a small hole will give access to the Mini-B USB port. If we ever ship code updates, we will provide a "click here" file. If you want to roll your own, you will need an AVR or Arduino IDE.
Software wise, we picked up a couple of small suggestions. Adding a mode for charging that shows all letters of TESLA in Green. Adding a brake light mode to scroll center out. And, one that I'm working on during the delay, but still can't fully promise either way (until I figure a couple of things out): A "Timeout" while "Parked" that causes the module to automatically switch to (your choice of) immediate displays.
Given board ship time, and a bit of testing to verify we've really solved the reliability problem, we should be volume shipping in the first half of May.
That's it for now... one reason I'm writing is because this is your final, final, final chance to get those ideas in!!
