Hi Tim,
Thanks for chiming in the thread. I'm still learning about all this so thanks for your patience.
My Model 3 will be MSM and am still debating spending money on a wrap. Is there a brand of clear wrap that's better for a darker color? I can't spend $6k to wrap the whole car but don't want it obvious what parts are wrapped and what parts are not. At minimum, the front bumper would be done. Do you wrap the front bumper with a single piece? Custom or kit?
How does warranty work on the labor with these types of things? For instance in the video you linked, dust was building up on seams. To me, that'd be unacceptable after spending money to protect it. Does dust build up simply not happen with quality installs? If so, does a shop warranty that type of thing and redo the wrap?
I've used skins on my mobile phone for some time. Occasionally from being in a pocket, dust can start to affect the edges and a good looking phone becomes quite ugly. It's trivial to peel and reapply a phone skin, but a wrap on a car is a different league. What are the expectations a customer should have with this type of product and the shop chosen to do it?
Thanks.
Fantastic questions Nathaniel, thank you for asking! I'll go over each in detail...
There are pro's and con's to PPF, the Pro's are protecting your paint, peace of mind, etc. the only real con is the price commitment. Do take into consideration, there is no necessary need to wrap the full vehicle. The film is designed for high wear and tear areas of the car such as the bumpers, and forward facing surfaces, Hood, fenders, mirrors etc.
Most films on the market will all offer great optical clarity, some are slightly clearer than others but its very minimal. For a color like MSM you really cant go wrong with any 10 year warrantied, self healing PPF brand.
Those dirty edges are not covered in any film warranty, fit and finish is outside the scope of any manufacturers warranty and would fall under the hands of the person whom has installed it. Installations should not build up debris overtime in the edges when done properly, usually if there is a problem its due to the fact that areas were improperly sealed or aligned and the adhesive side of the film is no longer bonded to the paint and now collecting dust and dirt.
You can see first hand just how difficult film installation is, its truly an art form. Imagine covering 3 dimensional surfaces on the exterior of a vehicle with minimal imperfections, its not an easy thing to do at all and thus what really starts separating a good installation from a great. There is no such thing as perfect, minor imperfections can be possible on certain parts of the installation but when done right are not obvious or detract from the appearance. Some panels cannot be wrapped such as between fenders and bumper so there will be a few edges you can see up close, but how these look can vary from shop to shop. If there is a large gap, uneven cut, dirt build up etc. most likely it wasnt done to its fullest potential. Some shops remove bumpers and large panels to wrap between, I don't do that nor recommend it do to possibility of broken or misaligned components/voiding warranties etc. In addition these panels tend to be too tight/rub overtime and cause the film to lift anyways, so there is a balance between coverage as well as aesthetics and really comes down to an installer that is experienced enough to know that difference.
Hope that helps!
