Gerardf
It takes 2.5 hours and yes you can wait while they perform the procedure. I strongly suggest you book the first available appointment in the morning (8 am in my case). I had the treatment done at the Watertown service center in Massachusetts and the treatment went smoothly and successfully. My MCU now looks great. Only time will tell if this is a fix or a short term patch. On the negative side my IC also has the yellow banding though it's only visible when hit from behind or the side by direct sunlight so they saw and noted the problem but did not agree to replace the screen.
Thanks for the quick reply.
I rather wait there (Monday in Tilburg - The Netherlands) and get some work done on the notebook than return next day.
As I will be there early afternoon I assume it should fit.
