“Standard Range” = 75D? Is a range upgrade coming?
Discussion in 'Model S' started by Drlev, Feb 28, 2019.
  1. Drlev
    Drlev Member
    Harrisburg, PA
    The “new” Standard Range Model S has identical specs to the 75D except range, at 270 miles vs 259 miles. The weight is exactly the same, the acceleration is exactly the same, the top speed is exactly the same. Logically, the battery in the Standard Range Model S would be 75 kWh. Simply put, they appear to have squeezed some additional range out of the battery. Does this mean 75D owners may be getting an 11 mile range bump over the air? Am I completely full of crap?
  2. PWlakewood
    PWlakewood Active Member
    US
    wheres the poop emoji when you need one! That would sure be nice though.
  3. Peteski
    Peteski Active Member
    UK, Milton Keynes
    The standard range Model S is actually a software limited 100D. The specs on weight etc must be wrong.
    • Disagree x 1
  4. Verranzo
    Verranzo Member
    Denver
    They stopped making the 75 kWh battery pack few weeks ago. The standard range Model S is now a "software limited" 100kWh pack.
    • Disagree x 1
  5. Drlev
    Drlev Member
    Harrisburg, PA
    Are we sure of this? The reduced range version available until today was a Software Limited 100D and weighed the same. This one is clearly the weight of a 75D
  6. Peteski
    UK, Milton Keynes
    I'm not aware of the 75 kWh pack suddenly being re-introduced. That doesn't make any sense given the reason stated for dropping it only a few weeks ago!
  7. Tesomega
    Tesomega Member
    Pittsburg, CA
    Model 3 range is being increased with the software update.. Could the range change be related to that?
  8. quickstrike12
    quickstrike12 Member
    Fort Worth Texas
    And a 75 kWh battery can’t go 270 miles.
  9. MS_Dream
    MS_Dream Member
    Zephyrhills, Fl
    Put another way, the RWD Model 3 range was software-limited to 310 mi. That limit is being removed.
  10. dennis_d
    dennis_d Member
    TX
    Standard Range model most likely has 14 modules of 100kwh pack which put it roughly at 85kw , which can explain weight of 75D and rage of 270 miles.
  11. Krash
    Krash Data Technician
    Intermountain US
    #11 Krash, Mar 1, 2019
    The software locked standard range S had the equivalent of 92kWh based on range and was definitely a software locked implementation of something larger capacity as it had option code BR06.
    BR05 was the lock code for the non US BTX8 which is on older P85 battery design from but a true 16 module, 400v, 85kWh battery - locked down to 75kWh.
    I assume that Tesla is consolidating the S/X battery chemistry since the old 14 module chemistry was different than the 16 module.
  12. Peteski
    UK, Milton Keynes
    I was under the impression Tesla specifically stated that all the S/X variants now had the same 100 kWh battery and the base models were simply software locked to reduce range. Other than this anecdotal evidence in the configurator, I haven't read any news of a new 75 or 85 kWh or whatever battery pack. If it was real, I would expect the usual Tesla/EV websites to have covered it by now?
  13. Detay
    Detay Member
    Sweden
    It has the same range (270) miles as the 85d had earlier. Which implies that it has a similar capacity. Why put a 100kw battery in it and lock away 15kw when you can use a 85kw pack.
    Maybe the European BTX8 batteries was a test and that they now use these batteries in the standard range model s. ;)
  14. Krash
    Intermountain US
    Looks like this was just for convenience for Tesla while removing the old 75kWh modules from manufacturing.
    BTX8 has the same serial number as the P85 battery and is 400v with 16 modules. The current standard range battery is 350v with 14 modules, likely just the old 100kWh with two modules removed.
  15. Peteski
    UK, Milton Keynes
    So they have a single spec to manufacture and there is always the chance of selling the additional capacity later as an aftersales upgrade. Tesla have stated this anyway and they've done it before. Software locking battery capacity isn't a new concept for Tesla.
  16. dennis_d
    dennis_d Member
    TX
    14s 100kWh pack module should be around 88-89 kWh, which is more then 90 kWh pack. if you take into account 4 kWh buffer. And technically it should charge faster since it has more cells , not as fast as 400v pack but still.
  17. Detay
    Detay Member
    Sweden
    Ah.. I see. Didn't know that the voltage of the standard range was communicated/known yet. But that does lower the chanses for higher charge rates for standard range cars.
  18. bob_p
    bob_p Active Member
    Unless the order page states an after delivery upgrade to long range is possible, owners should not assume this will ever be available.
    Unless Tesla wants all customers to order standard range at delivery (losing near term revenue), and decide later to purchase the long range upgrade later (if ever), it seems more likely customers buying standard range today - will never be able to upgrade to long range in the future.
  19. dennis_d
    dennis_d Member
    TX
    "Standard" model is more then 100lb lighter then "Long range" which is roughly a weight of 2 tesla modules
  20. whitex
    whitex Well-Known Member
    Seattle area, WA
    Tesla was opening new stores and telling everyone how it's their key strategy for success less than 2 weeks ago. Now they are closing them. Welcome to agile business model.
    I suspect software locked LR numbers are a few hundred at best, or maybe never produced at all, like the original S60D (sold for 2-3 weeks, never produced).
