Inadvertently charged to 100% and now can’t drive for 3 days. What is the best way to get charge down using remote app?
Is this actually an issue? Genuinely asking.Inadvertently charged to 100% ....
No not an issue but not optimal for the battery over the life of the car to charge to 100% and leave it there repeatedly.Is this actually an issue? Genuinely asking.
Charging and leaving a battery, whether a (Tesla or a cell phone) repeatedly degrades the life of the battery.Is this actually an issue? Genuinely asking.
No, If you accidentally charge to a 100% it's best to get the charge level down, as soon as your reasonably can. Driving it is a great way to get the charge level down out of the 100% range. If you can't drive it then you could as suggested above vent the windows, Turn the heat on max, just to remove some of the high state of charge on the battery. But if you could go out and drive it that would be the best actually.Not quite understanding. If I accidentally charge my MY to 100%, I should let the battery drain a bit before driving the vehicle to protect the battery?
Do yourself a favor and switch to percentage, then typically run between 90% and 20%. If you're on a trip, do whatever charge it takes to get you to the next supercharger. I have a short commute so I typically charge each night to 60%.great info. New noob owner.
So for MYP, don't go below 60 miles left and over 270 miles?
Seems like a good idea to just stick with battery % and not miles since the latter is derivative, but not an absolute analog of the former.great info. New noob owner.
The beautiful thing is you don't have to stick to one or the other. Just tap the icon on the screen and go back and forth to what you like at the timeSeems like a good idea to just stick with battery % and not miles since the latter is derivative, but not an absolute analog of the former.
Always cheaper to charge at home. I'd feel free to charge up to 90% when I stopped or even more while travelling. But that's depending on your trip and where you're charging and how long you want to wait. You're fine going to 90% I think especially on trips. IMODid not know you could touch the xxMIles part and it switches to %. Prefer that option. Thank you.
So, if I'm going to say drive from LA to SF, ok to charge at 100% prior to leaving but for every day use, 20-80% is the best option?
Something else I discovered just the other day that others may know but was new for me is that if the super charger place is crowded they will only allow you to charge to 80%
I can think of 2 reasons people may want to.You can yes. But if you can do it, say with the same number of charger stops, by just charging to 80-90% why still do 100%. Not a big deal either way.
