I've recently acquired the model 3 and only charge it at the supercharger next to the apartment. I'm assuming the 14-50 adapter is used with the home charging set up, which I don't have. I did get a mobile charging kit.
What is the benefit of having the 14-50 adapter and can I only use it with the mobile kit for charging at home?
Sorry, the tesla rep didnt go over much when car was delivered
I am not an expert, and there is a LOT of discussion about charging options on this and other forums. That said:
- Having a nearby supercharger is great. You are lucky. But I am unsure whether charging everyday on a supercharger is the best thing for the longevity of your battery? Maybe be sure to set your in-car software to only charge up to 80% (except when needing 100% for a long trip)? Let's hear from others about this.
- A (Gen 2) NEMA 14-50 adapter ($35 at Tesla) is (now) an option to be used on the Gen 2 Mobile Connector (charging cable) that came with the car. (They used to be provided by Tesla. Now you have to buy one.)
- It can be used on-the-road at places that have a corresponding NEMA 14-50 receptacle (e.g., RV parks, etc.).
- But it can be most helpful for daily charging at home, but only if there is an available 240-volt NEMA 14-50 outlet. Outlets can usually be installed relatively easily, however that may not be possible if you live in an apartment.
- NEMA 14-50 adapters are nice because they allow a car to easily and safely charge overnight at ~240 volts and up to 32 amps.
- Earlier in the history of Models S and X, the 14-50 charging option was more important and the 14-50 adapter was automatically supplied with every car (since the alternative of using just 120 volt outlets took so long).
- But with the creation of (Tesla) wall connectors, Tesla has really tried to steer buyers to that option.
