I have the option to by a MX slipstream rim set in 20 inch, but 9J front ET35 and 10j back ET35, presume this would be too wide for the Model S? If possible what tires would I go for? 245/40 front and 285/35 back?
Tires are 245/40 and 285/35 Michelin Pilot Super Sport.
I paired them with falken azenis fk510 245/40/20 front and 285/35/20 back. overall, i'm very happy with the look and the performance! the staggered wheels feels very stable and since my Model is RWD(S75), i do believe it makes a good difference. Enjoy the pictures and let me know if you have any questions.
This guy went with:View attachment 303868 View attachment 303869 View attachment 303870
Rather terrible photos but it's all that i have access to atm.
I went with 245/40 and 275/35.
I wanted a factory look, sticky rubber, and the freedom to drive without the fear of imminent pothole related wheel damage. The 20" Model X Slipstreams fit perfectly and only a Tesla aficionado would ever know they aren't a stock fitment.
Wheels are 20x9 ET 35MM and 20x9.5 ET 40MM. Tires are 245/40 and 285/35 Michelin Pilot Super Sport. No rubbing (except the fronts in reverse at certain angles, like the OEM 21s), no issues.
View media item 116622View media item 116621View media item 116623View media item 116624View media item 116625
What tires did you get and how much did they cost?Just finished mine, 20" wheels off an x running 245/40/20 front and 275/35/20 rear runs and drives just as good or even better than the 19" no rubbing
Sweet! Did you have to use any spacers?Just finished mine, 20" wheels off an x running 245/40/20 front and 275/35/20 rear runs and drives just as good or even better than the 19" no rubbing
You mentioned the MX TPMS worked on your MS. What year is your Model S? I have a 2013 and no luck with the MX TPMS.Didn't care too much for the tires as long as its quiet so I just purchased some Nankang sport tires on amazon for under $400 for the entire set. No spacers needed and the TMPS sensors off the X work great on the S. Thanks!
They switched to a newer TPMS system in both X and S at some point. I can't remember the year, but my old S was a 2013, and I needed something done at Tesla to make it work with the newer TPMS setup they currently use. I'm not sure what changed inside the tire, but after the "upgrade" I went from just getting general "low pressure warning" with no indication of what tire had low pressure, to a 4 tire readout, so I could see each tires pressure individually.You mentioned the MX TPMS worked on your MS. What year is your Model S? I have a 2013 and no luck with the MX TPMS.
Thanks
Correct. Your 2013 and my 2014 were the original Baolong sensors and receiver. To use the MX sensors (Continental) in your 2013, you would need to have an upgrade to the rest of your car to a Continental receiver AND have the car's software updated by a Service Center to recognize the new gear. You then get the individual tire pressure readings as an option in the driver's instrument cluster. Otherwise, you could put your 2013 sensors into the MX wheels and not do the upgrade. Or, possibly get new sensors (Baolong compatible) that *CLONE* the unique ID of each sensor you have per wheel and put them in the same location left/right front/rear.You mentioned the MX TPMS worked on your MS. What year is your Model S? I have a 2013 and no luck with the MX TPMS.
Thanks
I presume the back rims are 9,5 or 10J wide, if you put that on a 245 wheel, the tyre would not sit well and the rim would 'poke' out to the side. I would double check that for sure...
