2017 Chademo Tesla Adapter Not Working With Charging Stations
Discussion in 'Model S' started by Evoforce, Aug 23, 2017.
Tags:
  1. Evoforce
    Evoforce Member
    Fountain Hills AZ
    #1 Evoforce, Aug 23, 2017
    Quick Charging Stations are not currently compatible with chademo adapters purchased after May 2017.
    Tesla says they are currently working with charging station companies to enable it to work but provided me with no timeline or alternative.
    A friends adapter, purchased a little over a year ago, continues to work.
    Tesla was not forthcoming with much information but it appears to be a software update is needed at chademo quick charge stations for the new but visually the same looking adapter to work.
    I don't know why or what they changed internally to cause this.
    • Informative x 4
  2. jjh1234
    jjh1234 Member
    Pittsburgh, PA
    Hmm, I bought my adapter around the middle of May 17 and I've used it at least four times at different places without issue since then.
    Dunkin' Donuts, Pittsburgh, PA - EVgo
    Sheets, State College, PA - Not sure of owner, but took credit card directly
    Nissan dealers in Wexford, PA and Chantilly, VA
    I'm not sure when the cutoff was when they stopped working. Maybe I'll try mine again to see if it still works. Haven't used it in a few weeks.
  3. Evoforce
    Evoforce Member
    Fountain Hills AZ
    I ordered in mid May but they ran out of stock. Mine didn't ship until June.
  4. stopcrazypp
    stopcrazypp Well-Known Member
    Are you sure it's on the charger side and not the adapter that needs the update?
    The current version appears to be 1036392-10-D.
    Here's another report of an issue with that version:
    Suggestions for a Toronto-Montreal-Quebec City-PEI (and back) road trip?
  5. jjh1234
    jjh1234 Member
    Pittsburgh, PA
  6. Evoforce
    Evoforce Member
    Fountain Hills AZ
    #6 Evoforce, Aug 24, 2017
    They sent me an email stating that the charge station companies need to update and that Tesla is actively trying to work with them to do that. Your guess is as good as mine as to what the truth is... I am just frustrated that I have an expensive adapter that I need but cannot use. And I have no Idea when that will change.
    In reading the above linked post, they did indeed later in the post, state that the update was to the DCFC Station. It is scary to think, that if I am traveling across the country, that the station that I may need is not going to be compatible, when I am setting on few electrons.
  7. widodh
    widodh Model S 85kWh
    Middelburg, The Netherlands
    Just to check, is the adapter still rated to 125A? Does it say that on the label?
  8. Evoforce
    Evoforce Member
    Fountain Hills AZ
    Yes 125 ADC
  9. kort677
    kort677 Banned
    florida.
    interesting, is there a software update for the older chademo units? mine is 2 years old, does it need an update and if yes how could I get it updated?
  10. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    Hmmm, we are going on a road trip tomorrow that does require one Chademo stop. We haven't tested my husbands adapter out, and it is brand new, so might have this issue. Mine I bought used from another owner (and it works).
    I think I will throw my adapter in his frunk for the trip just in case his doesn't work. It would be very disappointing to have to hit a J1772 instead when we were planning on a quick charge at the Chademo.
    I don't understand why the fix is on the charger side when it apparently only affects new adapters? That sounds like something Tesla changed that they could change back.
  11. mazeminder
    mazeminder Member
    Toronto, Canada
    When an update is available, you take it into the service station for it to get updated (I was told this by a Tesla employee yesterday).
    Would love to hear how this goes. We'll be doing the same in early October with a *new* adapter and I'd be interested in hearing your experience.
  12. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    This procedure is true, however.... The problem is that you are not notified in any way that your CHAdeMO adapter has a new firmware available. I bought mine new from the SC (June 2016) and immediately was experiencing some anomalies. I brought the car and adapter back to the SC. They found that there was a newer firmware available for the adapter and updated it.
  13. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    If you are close to a SC, I would recommend stopping in sometime and ask them to check/update the firmware on your adapter. If you've never had it done, I can almost guarantee there is an update available.
  14. kort677
    kort677 Banned
    florida.
    I will try doing that and I'll post a follow up
  15. doubleohwhat
    doubleohwhat Supporting Member
    Alabama
    My concern would be that a firmware update would introduce the problem the OP described to a previously working adapter. I purchased my adapter in October 2016 and it has worked flawlessly since.
  16. swegman
    swegman Active Member
    There have been numerous firmware updates to the adapter as new type chargers are built. I take my adapter in with the car every time I take the car in for its annual checkup, and there usually is a firmware update made to the adapter. Further, I have Tesla check my adapter for updates whenever I go on a long trip where I might need to use the adapter. Mine was last checked about 2 weeks ago and was up to date.
  17. JohnnyG
    JohnnyG Weee!
    Columbus, OH
    The Signet chargers used by Greenlots and a lot of municipalities and very persnickety with how you activate them and in which order you connect / disconnect things. Even when getting all of that correct, your car will throw multiple errors after charging completes, until you unplug it. That said, getting past that, they work great to charge your car.
    The ChargePoint chargers seem to work a little more straight forward and I don't get a bunch of errors on the car when the charging completes.
    I haven't used any other DCFC other than those two companies units. My CHAdeMO adapter was purchased 06/2016 and has the latest firmware.
  18. Evoforce
    Evoforce Member
    Fountain Hills AZ
    To get back on track, Tesla says these newest adapters don't need updating but the DCFC stations do... That is why it can be a scary proposition that the station that you need to visit, may not be updated to talk to your new chademo adapter.
  19. Az_Rael
    Palmdale, CA
    Which makes no sense. The old adapters work, the new ones don't. Why is this not Tesla's problem to solve?
  20. Evoforce
    Evoforce Member
    Fountain Hills AZ
    Exactly! And why I was slightly put off by their email reply which seems to put the blame on DCFC stations and offering no other solutions other than saying they are actively working on it. They told me not to return the adapter for a different one because it is the problem of DCFC charge stations but offered no timeline or expectation of when their product (chademo adapter) will work!
