I have a 2018 Model 3 Performace I recently updated from a 2022.28 version to a 2022.44 version (I don't have wifi where I park). Shortly after (immediately?) running the update my heater stopped working. The fan blows but it blows cold. I was part of the group of people that had issues with the heater not working after an update last winter, but that was fixed with a subsequent update. I've updated the car again to 2022.44.30.10 and have rebooted the car using the steering wheel but the heat still isn't working.
In the HVAC menu I get a message "Climate keeper unavailable due to system fault" but am not showing any active alerts. However if I enter servic mode I'm showing two relevant alters, "VCRIGHT_a262_PTCFaulted" (PTC heater is faulted due to the reason set in the alert context data) and "VCRIGHT_a538_hvacSystemNotNominal" (The right vehicle controller (VCRIGHT) detects the HVAC system in not nominal due to a condition, which may cause Climate Keeper Mode functionality to be limited or unavailable.)
After running the second update I attempted to start the climate from the app to see if the heat would run, and it did for about 30 seconds heating the car up a few degrees, but turned itself off shortly afterward and now when I attempt to I get the message Climate On failed Climate failed to start.
Is this a problem anyone else has seen with this update? Is it possible the update caused this or is this just a PTC heater failure with coincidental timing?
