Clarifying (again) my prior post - this seems to be the limit for now (it is 31/46*250kW, based on SR+ physical quantities) but it is far from clear that this is the actual limit. You can probably tell by comparing the
width (or perhaps just the taper point would be better since current limitations interfere on the low end) of the peak plateau vs. an SR+ (or AWD for that matter) - will give you an estimate of the artificial throttling of the RWD Supercharging, if any.
Your 50% 150kW result suggests substantial throttling of the peak. Fortunately this makes relatively little difference to charge time in most scenarios.
Here are ideal large capacity NCA battery
profiles for reference - these will get scaled down for a “narrower” pack (e.g. SR+ NCA) - and again I do not track the structure of LFP packs or their charging limitations.
Taper seems to begin around 25% so if it happens later for the RWD then that
suggests it is artificially capped. (And you could extrapolate back to the theoretical peak which
might be 185kW or so.)
