Huh? Just because there is 3 phase at the street doesn't automatically mean a (single family) residential customer will get anything other than split phase 120/240.
Just so we're clear about all this:
High tension AC transmission systems are almost always 3-phase, usually at some ridiculously high voltage.
Substations, in general, take the high voltage and downconvert it to something lower: 800 3-phase, 440 3-phase, something like that. You'll see this as the heavy wires up near the top of some, but not all, of the power poles on a street.
I Have Been Informed by, apparently, long-term practitioners of this kind of thing, that a Power Company will take two of these high voltage phases, connect them to a Honking Big Transformer and, out of that, generate the split-phase used by a group of houses. That's generally for residential.
However, commercial people often have high-voltage motors and such floating about and those generally Work Better if supplied with 3-phase power. (Easier to get the motors to run in the correct direction when starting, if nothing else.) So, in the back of a typical supermarket there might be 3-phase 440 coming in, 3-phase 120/208 coming out, and breaker panels with the A,B,C regime rather than the One-Phase/Two-Phase that residential people see.
However, having said that: No Rules Are Broken if, on some residential street or other, there's a 3-phase transformer with 480 VAC in, 3-phase 120/208 out, and
pairs of the 120/208 are delivered to a bunch of individual houses. As pointed out in the comments, above, where some fellow in Queens stated that that was the case in his neighborhood.
The only reason we're banging back and forth on this topic is that the OP stated that he had an electrician give him, specifically, a 208 VAC socket, but also implied that his house was on 240 VAC.. and the 240 VAC would have been split phase, so what the heck is going on?
