Did you do the install?Hello! EcoHitch installed todayLove it!!!!!
Oh, I should mention that I skipped adding the whole weird looking handle/magnet thing to the knock-out panel. I'm fine with leaving the panel off for the most part (I'll probably have the rack attached most of the time anyway). And I can always attach the panel and just use a thin tool to remove when needed - it's not hard. I kept the parts if I ever decide to drill holes in the knockout and add the handle thing. I'm kind of waiting to see how Tesla handles this with their factory installs - maybe they'll have an option that works/looks slightly better than the one that comes with the EcoHitch.I'll jump in here and provide some more info since it looks like I have a similar setup to what Arrrse7enfold has and my purpose of the receiver is for a bike rack only. I received my EcoHitch from Torklift a couple weeks ago planning to do the install myself. I'm comfortable working on cars, building things, DIY projects, etc. Video didn't seem too involved to me, but I will say that I felt the actual install was a bit more involved than what the video leads you to believe (in my opinion). I get the sense they had things pretty well prepped ahead of time in that video. Getting the tail lights off were a pain - different setup than the M3 where you just have to pull back some soft liner to get at the bolts. The Y has hard plastic you have pry back making it hard to get at the bolts. And then you hope you don't drop one down into the deep well below! I then ran into a stripped under bolt (stripped from the factory apparently) which was a pain to deal with. Got as far as removing the bumper and that's when I threw in the towel - couldn't figure out how to unclip the whole thing and got a bit nervous after multiple attempts at bending it awkwardly. I'm lucky that I live about 25 miles north of Torklift, so I just packed it up, bolted it back on so it wouldn't fall off and took it to Torklift to finish up. Was in and out in about an hour, no issues. If you do attempt yourself, make sure you have a good set of trim/molding removal tools - the wheel fenders were a bit tricky to pry off!
End result looks great - really happy with the hitch itself and the work Torklift did. One thing I noticed is that with my Kuat rack in the folded up position, backup sensors go crazy as others mention. Also, when driving, red indicators are always on (see pics). I haven't tried it with the rack down or with a bike on it yet - that's tomorrow's project. Either way, it doesn't bother me all that much. It does raise the question of if they'll eventually implement some sort of "bike rack" button you can press that just disables the sensor warnings when attached - I don't really need the whole "trailer mode" as this is only for the bike rack. I have to imagine trailer mode may do more than just disable sensors? Either way, I'm good with it and very happy. I definitely didn't need to go the factory Tesla route for my needs.
View attachment 541885 View attachment 541886 View attachment 541888
Where did you get it installed? I'm thinking of getting one also.I paid $250 for the install. They did the knockout panel for me. The magnet is incredibly strong and it’s challenging to get back in place. I’ll probably add some accessory instead of continuing to use it.
that’s pretty lucky you live so close to Torklift !
Thank you! I have the same rack I will be ordering my hitch soonReceived mine a week ago and installed it myself in about 2 hours. I did have a spun bolt in the plastic tub, but it was forward and didn't have to be removed to pull the bumper. This is a problem Tesla needs to fix. Anyway, here is a 1up single tray on the Model Y with one of the bikes I manufacture. You can open the hatch with the single tray without lowering it. View attachment 543160 View attachment 543161
Are you able to open the hatch with two trays attached without lowering it?Here is the 2 tray and the 3 tray on the Model Y as well, so you can judge what you want to run. View attachment 543168 View attachment 543169
No, You will have to lower them 45 deg. when you have more than 1 tray on, or the 2 tray base.Are you able to open the hatch with two trays attached without lowering it?
I think all of us may need to request a software update from Tesla to add a bike rack mode button on the screen to cancel out the annoying message that causes issues with Autopilot while driving. When the rack is in the up position, a message sometimes pops up saying the sensors are blocked, and autopilot has limited functionality.I'll jump in here and provide some more info since it looks like I have a similar setup to what Arrrse7enfold has and my purpose of the receiver is for a bike rack only. I received my EcoHitch from Torklift a couple weeks ago planning to do the install myself. I'm comfortable working on cars, building things, DIY projects, etc. Video didn't seem too involved to me, but I will say that I felt the actual install was a bit more involved than what the video leads you to believe (in my opinion). I get the sense they had things pretty well prepped ahead of time in that video. Getting the tail lights off were a pain - different setup than the M3 where you just have to pull back some soft liner to get at the bolts. The Y has hard plastic you have pry back making it hard to get at the bolts. And then you hope you don't drop one down into the deep well below! I then ran into a stripped under bolt (stripped from the factory apparently) which was a pain to deal with. Got as far as removing the bumper and that's when I threw in the towel - couldn't figure out how to unclip the whole thing and got a bit nervous after multiple attempts at bending it awkwardly. I'm lucky that I live about 25 miles north of Torklift, so I just packed it up, bolted it back on so it wouldn't fall off and took it to Torklift to finish up. Was in and out in about an hour, no issues. If you do attempt yourself, make sure you have a good set of trim/molding removal tools - the wheel fenders were a bit tricky to pry off!
