MassModel3
Bear in mind that a supercharger currently will add roughly 50% charge to a battery in 20 minutes. The rest of the charge takes more than twice that long due to tapering. A larger battery (400 miles) means that a SC stop can add 200 miles to your battery in 20 minutes and that would accommodate the quick stop and maximum recharge. With smaller batteries, you'd have to sit longer (maybe lots longer) to get that 200 miles added to the battery. Point is that even if you can't or wouldn't drive 400 miles straight, a 400 mile battery will seriously improve your long distance commute times even if you do stop to charge frequently.
- - - Updated - - -
As I understand it, the Model S's going to Europe are not fully assembled prior to shipment. The parts all get shipped, but they go to a European factory for final assembly. This is a way of saving on import taxes. I would think the China factory would be the same thing, simply performing final assembly locally. Have no fear -- there's no way you're going to be buying a Model 3 that was built in China.oh man... model 3 built in CHINA??? ....:cursing:
- - - Updated - - -
Didn't JB Straubel say the Model 3 will have 300 miles when he recently spoke in Nevada (a couple weeks ago)? Maybe I'm hallucinating (again), but I think he did.I believe that Tesla will make improvements in aerodynamics, weight, efficiency in the inverter, motor and HVAC and in many other areas so 300mi range is very likely.
