Agreed, the following is misinformation:
"Heat pump would have no impact on measured results, even if using 5-cycle testing - the 5-cycle testing only engages A/C in the hot test and never turns on cabin heat in the cold temp test (there is no reason to, since that would have no significant impact on results in an ICE vehicle)."
Thanks for the info. This has been pretty confusing for me to track down - I was reading a publication from the EPA (but I guess it was quite dated) indicating that it wasn't needed. Thank you for your link.
But this makes a lot more sense...looking at some cold weather test data from Teslas and it does look like it significantly impacts the efficiency...which is great as at least it means 5-cycle testing might actually have some significant impact on the results...
Here is the
erroneous table I was looking at in an old document:
But doing a search for "heater" in that document...
Sorry for misinforming you. As you can see above, I was going off this table, which is apparently dated...
I guess it remains to be seen whether the Model Y has a heat pump? I'm having a hard time understanding how that scalar of 0.756 could have gotten so large without one, but who knows. I'm stumbling around like a blind man on this stuff, gradually learning my way as I go.
Sadly, even the "Test Details" tab in this EPA link is ambiguous/does not speak about heat - but I will trust the link provided above in
@bhtooefr's post.
Detailed Test Information
