40A vs 32A -- Gen 1 vs Gen 2 Mobile Connector
I have a 2015 Model S 85D and just purchased a 2021 refresh Model S LR.
So.... now I have a Gen 1 Mobile Connector from the 2015 that charges at 40A. I was a little surprised to learn that the new Mobile Connector (Gen 3 apparently?) will only charge at up to 32A.
I will be selling the 2015 and figure I should give the buyer a charger so now I wonder which to keep and which to give away with the car.
My thoughts:
  • Better to have the newer charger (2 years old vs 8 years old)
  • But... 40A is better / faster than 32A
  • But... I pretty much charge overnight exclusively and either way car will be full by morning.
  • But... Every once in a rare while there that time where car is empty and want to get it charged up as quickly as possible. 40A would be nicer for this.
  • But... That's a rare scenario for me and not a big deal to go to a Supercharger
  • But... Supercharging is no longer free for me 😭
Thanks for listening to my thoughts playing ping pong. I'd love to hear your thoughts.
I would do the following:
  • Give the old 40a mobile charger to the new owner of your 2015 MS
  • Install a HPWC at your home with 40a max charging speed (No additional wiring changes needed, if you wanted to charge at 48a you would probably need thicker wire and a 60a breaker instead of 50a)
  • Keep the new 32a charger in your frunk and only use it when traveling
I charged for 2-3 years with a 40a mobile charger as my main home everyday charger and the button to open and close the door wore out (not a big deal but still something to think about). I installed a HPWC and it is much more study and meant to be used everyday and it's nice to always have my mobile charger with me.
Btw the newer Mobile Connector is called a gen 2. Gen 3 is the latest Wall Connector.
Theres a reason Tesla went to 32A charging with the gen 2 mobile. These forums were filled with people having melted their 40A charging adapters. Apart from the amp difference, gen 1 doesn’t have heat sensors in the charging plug, while gen 2 does. In my mind that is a massive win.
These are all useful comments. Thanks!
After reading your comments, I think it makes sense for me to keep the newer Mobile Charger (Gen 2 I guess?) with the newer car and give up the older 40A mobile connector with the old car. My outlet is a 50A outlet, but when it was installed the wiring was put in to support a 60A circuit using heavier gauge copper, so it would be easy for me to install a HPWC.
Based on many posts, don’t assume this to be true. All too often the “60A” wire is actually rated at 55A, specifically #6 Romex. Just file this fact away for later as something to confirm if sometime decided you want to run a wall connector at 48A.
Good point. In my case, it #4 AWG copper wire running through conduit and I made sure that 3 conductors were run through the conduit.
The less prevalent scenario where that extra 8A (or 16A if comparing Gen 2 UMC to Gen 3 TWC) could matter would be a second EV needing to charge from the same connector such that the faster the first vehicle finishes, the better.
My 2019 didn't come with a UMC so I sold my 2015 without a UMC. You could offer to throw in the gen1 UMC if the buyer is on the fence. I would keep the gen2 for travel and perhaps buy a universal HPWC for home. Adapters are harder to find for the gen1 now. I don't think Tesla sells them anymore, and the gen1 lacks the thermistor in the plug which helps protect from fire.
Reactions: jhumbo and aerodyne
When you charge at home every night what is the average total kWh you add to the car? You are choosing a setup to do just that so it’s a good starting point.
When I was waiting for delivery in 2020 I wired for the full 48A/11+kW. In 3 years I have never needed that speed and my garage is 100’s of feet from my meter so I prefer to charge at a lower amperage overnight.
