5 miles battery drain in a parked car per day
Discussion in 'Model X' started by New123, May 20, 2019.
  1. New123
    New123 Member
    Texas
    5 miles battery drain in a parked car per day. I charged the car with 250 miles and didn't use the car for a day. Now I see the miles remaining as 245 miles. Is this normal or should I check this with SC?
    Thanks,
  2. BigMskiman
    BigMskiman Member
    Pleasanton, CA
    I tested over 4 day vacation recently, miles went from 70 to 60 (WiFi always on, car not plugged into HPWC)
    It might depend on state of charge and other things you have turned on.....
    old |v2019.8.6|AP2,MCU1,PUP|
    new |v2019.12.1.1|AP2,MCU1,PUP|
  3. New123
    New123 Member
    Texas
    Thanks for the suggestion. I will check that. Also, I observed that the car lights are getting switched on randomly and is getting unlocked in the garage. Not sure if this is the cause of the battery drain. Also, the vipers are moving when I start the car inside the garage.
  4. DoctorVenkman
    DoctorVenkman Member
    Los Angeles
    Are you walking around with the keys in your pocket? It might be detecting your keys from the garage and waking up occasionally. In my experience battery drain is roughly one mile per day, so five seems a bit steep.
  5. New123
    New123 Member
    Texas
    No. I kept the car key inside the house, but near the garage. Not sure if that is detecting. But it remains locked when I kept the keys inside and randomly unlocks. I thought the same about the drain. I will check with the SC on this and will update the thread.
  6. RRM998
    RRM998 Supporting Member
    Pasadena, TX
    Is this a 2019 MX? For my 2016 model, if I have energy saving on in the display settings, I lose 4 miles a day and if it's off I lose 9-10 miles a day. I understand the newer models do better in terms of energy usage. "'Cabin Overheat Protection" and Sentry mode can also impact vampire drain significantly.
  7. New123
    New123 Member
    Texas
    2018 november. sentry mode is off in the garage. But, I set the AC on when the doors locked and I am away if the keys are inside the car. I will check if this option is causing any of this as I assumed that it works only if the keys are inside the car.
  8. posity
    posity Member
    Portland, Oregon
    Yes, this is normal. Don't sweat it. Mine loses 4-7 miles per night, have seen as high as 12 in cold weather. My understanding this is Tesla making sure to test/condition the batteries to ensure maximum battery lifetime. This drain is a good thing: go read about the Leaf where it does not have overnight drain but the battery life is abysmal. Folks spend a lot of time worrying and complaining about this in online postings, but none of us are privy to the extensive engineering that has been performed that makes Tesla batteries second to none. Give Tesla the credit they deserve for getting the battery life right.
  9. New123
    New123 Member
    Texas
    So per day 5 miles and per month we loose 180 miles without driving. :)
  10. thecloud
    thecloud As rhythm raced inside, the ship came alive
    Sunnyvale, CA
    #10 thecloud, May 20, 2019
    If you have an older Model S/X with MCU1, check that Energy Saving mode is on and turn Stay Connected off. My "vampire drain" is only 2-3 rated miles a day with those settings.
    Note: for a newer MCU2 vehicle, those settings might not be available.
    Edit: also, make sure your key fobs are nowhere near the car. If in doubt, try keeping the fob in an old Altoids tin, or a Faraday bag.
  11. New123
    New123 Member
    Texas
    Its a 2018 Nov build 100D. I will keep the key fobs far from the garage and observe for few days.
  12. P85_DA
    P85_DA Supporting Member
    It’s within range of normal I wouldn’t be concerned ;):eek:..as a matter of fact I lost 3miles overnight yesterday :oops:
  13. New123
    New123 Member
    Texas
    Thank you :)
  14. dgatwood
    dgatwood Member
    Sunnyvale, ca
    Interesting. I've done all of these things except disabling cabin overheat protection, but I still burn through ~10 miles overnight every night, so probably ~15–20 miles per day.
