Looks like the phantom drain is still there. I lost 4% in 16hrs. A trip to Tesla Service Center is definitely a must.
Did you use Teslafi?
Two good things!
1) You can se both the real SOC and the displayed cold SOC.
The displayed SOC is adjusted down to reflect the range loss due to cold battery.
Teslafi shows the actual SOC as marked below, and the displayed cold soak SOC in blue with the snowflake.
If you look at the app or car, you can not know the actual SOC so the lower displayed SOC can be taken as abnormal phantom drainage.
Teslafi will show the real SOC, so a cold battery could be ruled out as the issue.
(Or learn that this is the thing happening).
Cold battery can easily lower the displayed SOC by 3-5%
2) You can check if the car sleeps:
My MSP yesterday. I woke the car twice, both by entering it mid day, and being close to it blowing snow from it with a leaf blower late night before parking it in the garage.
A normal day, not used, it will wake itself 0 to 1 (max2 times) to charge the LV batt.
The darker areas is ”awake” and lighter colored is sleeping.
My MSP 23 will use about 0.1 kWh / 0.1% when parked for 24hrs without sentry mode.
When the car sleeps as it should, and only is awake for ~30 minutes a day to charge the LV batt, there is No possibility for the car to use several % per day.
Sleeping car = HV batt disconnected and more or less no consumption (except for waking up and chsrging the LV bat).
The stand by power is ~4-5W.
