@ssiegler
The worst thing about this story of a 500kWh battery is this:
even if one assumes that the battery technology in question has good enough numbers of power and energy and weight and cost to fit in a car, it still makes more sense from mathematical optimisation to have less:
- If the battery has 500kWh and can charge in 20 minutes: Why not nerf it to 200kWh and have it fill up in seven to eight for 600-800 miles range, like a petrol/diesel car, and have less degradation to boot?
- If the battery is cheap enough at 500kWh: Why not reduce to 200-250 kWh to increase production efficiency, over what is really going to be a very small, relatively speaking, marketing advantage of the increased range from 600 to 1500 miles?
- If the battery can only provide the power at 500kWh: Then why not increase contact area and cooling at expense of energy density? This is a fact common to the majority of battery chemistries: energy is a result of optimum chemistry, but power transmission is due to mechanical facts such as surface area, conductance preventative heat transmission and cooling requirements. Hence discoveries of Lithium-ion leading on to higher power, lower energy, longer lasting variants: LTO, A123's iron-nanophosphate types etc.
And don't get me started on charging tech and how long it would take a household to charge.
I don't care how much of a optimist or fanboy or expert these people say they are. It is genuinely
too much capacity in terms of relative physical fact,
alone, that is, regardless of hypothetically having no trade-offs, and possibly
resulting from any lack of tradeoffs. Batteries are an all in one source: energy
and power per weight. It is
so much, it is actually turned into a
disadvantage.
To be particularly damning, there is already a type of vehicle that could utilise this same shitty to an even greater extent: internal combustion.
Yes, your average Audi or BMW sedan could well have no transmission to the back and a 400-500 litre tank stuffed in the equivalent area to a Tesla (Yes, the back seats and boot remain free. Don't think I'm falling for that fob-off comparison.) which would give 5,000 miles of range.
And last time I checked, the ability to traverse the Sahara Desert is not exactly an extensive market.
This story is nonsense.
Therefore, the story is ended.
It is a dead story.
The story has been.
It is an ex-story.
End of story.
