The later S75 was also capable of being upcorked and achieving a 4.3 0-60. Mine was.Range difference is negligible IMO, 249 RWD vs 259 AWD.
0-60 is 5.5 for the RWD, 4.2 for the D assuming it is / can be uncorked.
I have a late '16 RWD. At the time it was the right decision, but when the whole uncorking thing happened I was pretty bummed about missing out on the performance increase.
I was not aware of this. Maybe it is a traction control issue, and it is trying to prevent wheel slipping? Or maybe it is a tire wear kluge to reduce rear wheel wear?We have a '17 S75D. I drove a S75 loaner for the day while our car had it's annual service. The biggest difference I noticed was in the relative lack of regen stopping power overall, especially during my commute. I didn't realize how much I had become used to one pedal driving until I drove the S75. I checked the settings (regen level and "chill") and they were the same on both cars.
Similar SOC and temperature. I believe it's strictly having 2 motors providing resistance during regen. Similarly, even though the S75D has to be heavier (2nd motor) it has a higher rated range due to the extra regen capability.I was not aware of this. Maybe it is a traction control issue, and it is trying to prevent wheel slipping? Or maybe it is a tire wear kluge to reduce rear wheel wear?
I assume there was not a limit due to SOC or temperature when you drove the RWD...
Sure, but definitely nothing manufactured in 2016 like the OP is looking at.The later S75 was also capable of being upcorked and achieving a 4.3 0-60. Mine was.
You may find that this is somewhat artificial depending on speed. If you stop or almost stop, then turn the wheel, the car turns much shorter. I think the car won't allow too sharp of a turn at speed to prevent flipping.Curve ball question, not related to OP
Does anyone know if the RWD cars have a better turning circle than AWD cars? Mine is AWD and sometimes I wish the turning circle was better. That got me wondering the other day of the RWD ones are better.
Just considering the weight of the car, for the RWD all the power is always sent to the rear,Whats the performance(0-60) and range difference between a 16 MS 75 and 16 MS 75d and
is there any other benefit to having the D if weather conditions are a non factor?
If weather conditions are a non-factor, a '16 MS75 and '16 MS75D should perform nearly the same. There is slightly more range with the dual motors and perhaps there is better regen capability, however the cars should perform almost identically.
Add just a little water to the road and the RWD-only car will tend to fishtail/lose control or spin tires, especially when accelerating quickly. Of course using a quality tire will improve things.
Driving dual-motor loaners is like night and day while in wet conditions vs. my '17 MS75. Seems like anything with a D will stick to the road like glue. You have to be a little more careful with the RWD option.
