as luck would have it
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have a photo on my phone as last time I used it I couldn't remember password so emailed the QR code to Admin to ask them to start a session for me ... so I was able to see the brand etc.
Ours look like this photo, as appears to be the case for all the marketing images on their website ... but I can't find any matching product, so probably there is a new model and the website not updated ...
Ours have a QR code stuck just above the "socket". The phone APP opens with a QR-camera widget (preceded by a LOGIN or REGISTER screen if not currently considered "active"). Get cable out of boot, Plug in, Open phone APP, Scan the QR code and basically that's it. (I think stop-charge, from the car, is enough to allow unplug - i.e. without having to get the phone APP out again, but I can't remember ... there is another charger at work, predating all that, which is the one I normally use ...)
For a visitor plug in own cable and then either photo the QR code or note the Stall No. and give that to reception - the Admin APP allows initiating a charge, as well as setting up a new "member"
It was installed by the people we have used for PV, PowerWall, Wall chargers etc. (you don't have a location showing so dunno if they would be local to you)
I assume the latest model is the "EO Genius" but the photo makes it hard to see much about it ...
EO Genius Blurb:
Charge up to 22kW
Built-in active load management
Restrict access using RFID or EO App
Charging insights via the EO Cloud
Dimensions
175mm x 125mm x 125mm
OZEV Approved
Eligible for the Workplace Charging Scheme (UK) (
** we got 50% subsidy for install, maybe that was this scheme)
Also:
EO Hub
Connect an EO Genius charger to the EO Hub and unlock smart-charging technology. Connect up to 30 charge points per EO Hub.
Key features:
Charge scheduling
Telematics integration
Manage and monitor energy usage
Cloud connected via EO Cloud
Revenue Generation
Monetise your charge points and charge drivers to plug-in (available in all territories)
EO Cloud
Cloud-based charge point management system suitable for fleets, workplaces, cark parks & charging destinations.
Key features:
Remote management of charge points
Monitor energy usage
Remotely diagnose & resolve issues
Monetise your charging infrastructure
www.eocharging.com
