Does anyone have any info on Model X 90D vs P90D acceleration curves? Obviously Tesla publish the 0-60mph times, but I'm curious on how to interpolate this to other speeds (ie, 0-40 and 0-50 times). From what I can gather the acceleration isn't linear.
I don't intend to go drag racing and rarely am I going to want to overshoot 60mph by much
Both cars (and most EVs) have basically two phases in the power limits.
At low speed, they are limited by either maximum motor torque or available traction - power increases linearly with increasing speed, acceleration stays constant.
At some point, the power required to sustain this acceleration reaches the maximum that the battery pack or motor inverters can deliver.
From that point on, the car puts out more or less constant amounts of power (actually dropping slowly due to back EMF issues,) and the acceleration falls off as a root of the increasing speed (nearly constant increase in kinetic energy, which is a function of velocity squared.)
During the initial constant acceleration phase, the P90D is much faster, due to the gobs of torque from the big rear motor. For a PxxD car, this phase ends around 25-30 mph I believe.
Above that speed, the P90D acceleration falls off while the 90D acceleration remains constant at its lower value, until the 90D becomes power limited (around 45 mph, I think?)
When they are both at the power limit, the P90D produces a small amount more total power (450 kw vs 400 kw I think it was?) but the difference isn't generally perceptible to most people I'm told.
TL;DR version: most of the extra fun in the P90D is to be had below 50 mph. Above that the difference is small.
