So we're looking to move the car into our backyard shed.
That's where all the fun tools are at, and also allows me to work on stuff day/night without worry of weather.
Then also, there's the lack of a need to use a car cover to keep the car "out of sight" to prevent a particular neighbor from reporting us.
So to do this, we need the car in "tow mode", but that's a bit complicated to accomplish when your MCU is not displaying anything and you don't have the touchscreen GUI memorized well enough to just poke the buttons without the GUI displaying.
HOWEVER! I found alternative ways to just put the car in neutral. This released the parking break (I could hear it disengage). So now we can most likely tow it.
Put on a tire, but noticed the supension is a little off... then realized this is because the control arms are disconnected from the left knuckle.
Also noticed that the left suspension knuckle is not bent, but CRACKED (considering the thickness of the metal of these things, that's some impressive force).
Since it's a bit of a hassle to replace such a knuckle, going to try and tow it with the broken knuckle, and then do a bunch of major replacements/repairs in the shed/shop.
Got a replacement left fender... y'know the side damage underneath the A-pillar doesn't look as bad when it's hidden behind a fender
Recently the car's been having some trouble starting up among other things, given that the car has been saying "replace the 12V battery" it's proably the 12V battery, and sure enough when you let the car sit without a constant battery charger hooked up the Battery is only producing
3V which I didn't even know a lead-acid battery could get that low.
So for the moment, going to re-charge that battery so that we have enough power to last us the tow, but then afterward I got myself a 1.2kW 12V power supply that will provide the car some more reliable juice than what the battery has been attempting.
