Why is this even being discussed? If you want a fast car and care about the future of Earth, get a Tesla. Otherwise go buy your fancy i8 or LC Hybrid -- Tesla doesn't want your business.
Discussion can lead to education. Thinking outside the box can lead to some innovative ideas, but thinking outside the box without understanding the physical limitations leads to fantasy. Understanding the difference can help out of the box thinkers come up with more workable ideas.
Just because the OP used the words "thinking outside the box" doesn't mean this idea actually does so. Let's turn a Tesla into a hybrid? Hybrids were a stepping stone on the way to full EVs. Regressing to inferior technology is not thinking outside the box.
I believe hybrid sales have started to drop as hybrid owners switch to electric now there are enough 200 mile+ EVs out there. The hybrid is a dying tech like CD players. You can still get them in some cars, but they are being phased out in favor of newer formats.
So, this idea essentially exists already, and has for a for years. It did not and does not sell very well, but I almost bought one in 2015.
The Honda Accord Hybrid has a primarily electric drivetrain. The gas motor is there to both supply electrical power and is coupled to the wheels through a single-speed transmission for more efficient and powerful highway travel, to make up for the lacking performance of the electric motor at highway speeds.
I think the Fisker Karma used the same approach as well. In another implementation, ever heard of diesel-electric locomotives?
At the time, I thought it was a brilliant form of hybrid. I especially liked that there was a single-speed transmission for the gas motor, used only at highway speeds.
What about the following "innovative" idea:Discussion can lead to education. Thinking outside the box can lead to some innovative ideas,
Groningen (Netherlands) company comes with a Tesla on hydrogen
'We have succeeded in hacking a second-hand Tesla so that it can run on hydrogen.
With this we can more than double the range."
That is what Stefan Holthausen said on Wednesday evening at the third edition
of the "Founder Talks" talk show in the city of Groningen.
The converted car is named 'Hesla'.
11/2/2017
Sales of hybrids are dropping as pure electrics begin to become more practical. Toyota dominated the hybrid market for nearly 20 years with the Prius, but Prius sales have been dropping in the last couple of years. Part of this is due to other Toyotas becoming available with the same drive train, but at least in the US hybrid sales peaked around 2013-2015 and have been in decline since.
This same above concept could also potentially be used in propeller based airplanes, keeping the airplane light weight, but giving it a ton more power. The only difference is you don't need the instant burst of power, so you'd eliminate the battery pack, and instead, just run the electric motor powered prop off the alternator from the ICE. The Lycoming engines used in Cessna's weight over 300lbs, and burn 8-10 gallons of fuel per hour. What if you could eliminate those 40+ gallon fuel tanks, replace it with a 6 gallon fuel tank, be able to fly twice as long on that fuel tank, AND have a lot more available weight to the passengers?
Most Cessna's have a usable weight of between 800-1000lbs... not including fuel. Once you add fuel in, you are down to 500-600 usable lbs of weight.. a 4 seater Cesna isn't really a 4 seater at that point, unless everyone weight 125 lbs. Make this change, and you've freed up an additional 400 lbs or so of usable weight capacity, and have more performance to boot! Of course, the air frame would have to be redesigned to handle the extra performance, or there would have to be a limiter put in to prevent the engine from pulling too hard.
