Cross-posting from here, where there's more discussion about it, and vague instructions if you'd rather make your own (more pictures on how to make your own are in the link below).
I've had a couple of forum members ask for their own 'Telsa T' as shown above and here, so I'm in the process of making a few of them. I'll cross-post this is in the Parts for Sale forum, but if anyone is interested, PM me. Cost is $300 delivered (US only), and is as shown in the photos - a dark metallic grey (a couple of shades darker than the Model S grey, and a bit sparklier). Note that there's a bit of work you'll need to do if you want to hide the wires, so some DIY ability is needed. In particular:
- The lights take a 12v feed (from the supplied wall wart PSU). I've put mine in the attic above the garage, and run it in the wall to exit behind the main section of the 'T'. I'd recommend doing the same, or running it up from an existing wall outlet, but still putting the wire in the wall if possible.
- The top section is connected to the main section with a small 2-core wire for power. Again, this is easily hidden in the wall, I just put a small hole behind the top section, and dangles the wire until I could grab it through the larger hole behind the main section.
- Finally, both parts hang using standard picture fittings, so if you can keep your screws level, you'll be fine. I guess the top section requires a bit of skill to get it positioned exactly right, but I didn't do anything special aside from eyeball it once the main section was up.
If all of this sounds like too much hassle, I could also mount the T on a back-board (painted in what I think is pretty close to the darker 'Tesla red' used in their stores for an additional $50. Just let me know if you want the power cable to exit straight out the back, or if you want it run in a channel on the back to exit at the top or bottom.
Note, dimensions are 30" high, by 36" wide.
Thanks, Pete
Thanks, Pete
