If you really want to make your Y's range look terrible:
- Base everything on what you see as you just start driving
- Things will settle down after you drive (like your return leg) so make sure you ignore those numbers at the end of the trip and focus on what your car tells you at the start
- Only take short trips (floor it!) so numbers look terrible
Do NOT do the following test:
1) Drive your 6 mile loop with the AC on and record the power dissipation (x kWh)
2) Drive your 6 mile loop with the AC off and record the power dissipation (y kWh)
3) Compare the two which will tell you if the AC if truly killing 50% of your range (y = 2*x)
A response on a similar thread:
Range Efficiency Question
Try longer trips. Short trips aren't efficient in any vehicle.
A ridiculous example--lets say your car is parked in your drive way.
A) Turn on your car.
B) Drive 5 feet.
C) Turn off your car.
D) Turn on your car.
E) Drive back 5 feet to it's original position.
F) Turn off your car.
Repeat A to F hundreds of times and you'll have traveled very little distance and expended a lot of fuel (gas, electrons) which will give you really awful efficiency.
