Adjustment to Fix Door Panel Spacing?
The only thing left after having my delivery issues fixed is the door panel isn't flush with the body. It's much more obvious depending how the sun hit it.
Took a photo, the door sticks out past the body and throws a shadow.
Will adjusting the striker fix this issue, or do I need to find a body shop that might be able to fix this?
I am having the same issue with my Tesla which I got exactly a week ago. I’ve set up a service appointment coming Friday for them to check out. They will most likely measure the gap to see if it’s “within the spec”.
You would be surprised at what experienced body shop guys do with this kind of stuff WITHOUT bodywork. In this case, I could see them actually trying to tweak the door a bit bending the top and bottom out ever so slightly so they can adjust the entire door inward (toward the inside of the car). Will it be perfect? Nope, but it might be "good enough".
Reactions: Magnets!
