With a MPY on order to replace my wife's car, my homework assignment is to look into installing a charger. I was hoping you all could recommend the best location in the garage given our specific situation.
We have a three car garage with the breaker panels on the wall nearest the single garage door. I park on that side since it is a tight fit with the wall close to the driver's side door and the water heater (with pole) in front. My wife prefers to park on the other side and still wants to park and charge the MYP - essentially she parks in the middle of the three car garage as we have storage shelves all along the wall on the opposite side. Here are some photos of that panel side of the garage to give some context:
The silver car is mine and you can see the pole protecting the water heater with some pool noodle on it acting as a bumper. My kids did that after someone bumped their leg on it.
There is room to add breakers in the larger panel on the right. The smaller one is full. The panels are mounted to wood along the sides but the bottoms of the panels are covered only by drywall so that should be easier to access from below.
From the photo above, you can see how tight it is on that side. I can get out of the car OK but my wife and kids had trouble before so we added matching pool noodles where the doors make contact.
While I would love the look of EMT for the install, a horizontal run alongside the car would be problematic down this wall. With concrete block walls, it's recommended to use hangers (or minnies) to keep the pipe off the wall to avoid corrosion. So EMT would stick out 2 inches from the wall which would not be good for opening my driver's door, and those hanger clips would scrape you if you walked by too close. Plastic conduit would allow the conduit to hug the wall and be kinder to the doors and not stick out more than the noodles. The charger would have to be closer to the rear bumper of my car so I could still walk down the side without having to shimmy or bump into it.
The space between the garage doors would be ideal but we hang our shop vac there so it could reach one side of either car. Plus this would increase the install costs for sure getting the wire up and over.
So far we've come up with two possible mounting locations for the charger and would appreciate your feedback on these and any other suggestions:
- Place the charger one or two feet to the right of the panels near the front wheel/bumper of the silver car in the photo. This would be about 15 feet in from the garage door.
- Would the charging cable be able to reach the MYP which will be parked on the other side (where the black SUV is to the left of the shop vac). We could route the cable in front of the silver car and down the side to reach the Tesla assuming the cord is long enough. Also, this would avoid me driving over the cable while she is charging.
- Place the charger closer to the garage door down the wall which would be about 9-10 feet to the left of the panels.
- One concern is the conduit run down that wall which I mentioned above. We'd need to make sure there is clearance for the car doors.
- Another concern is that the silver car would be driving over the charging cable while in use. Not sure if wall connector cables are heavy duty enough for that.
- One positive is that this would allow more range for charging cars outside of the garage where the first option would only leave 6 or so feet of cable reaching outside if needed.
Thanks in advance for your feedback.
