1russianguy
Wow!! that combo looks amazing! would you have specs on the wheels, including weight & cost?
Did you every get these mounted on your Model 3? Pics please!These are waiting for the snow to stop flying to be put on my Model 3. The stock 18” wheels have snow tires mounted on them.
Looks like HRE FF01 in either bronze or gold.Wow!! that combo looks amazing! would you have specs on the wheels, including weight & cost?
Agreed, let's hope I don't regret not attempting the 265/35/19's on all four corners.
It can be done! We did 265/40/19 on Enkei RPF1 in 18X9.5 all around and he's lowered.
That's a RWD right? Any reason to think it wouldn't work (esp up front) on an AWD?
When I asked tire rack about this they specifically said their system shows 265s are fine in the back but aren't listed as an option for front tires on the car.
I wish your site had the weights of the wheels.2018 Model 3 with 20" Forgestar CF10. Can't wait to see someone do the most popular design, the F14
Size: 20x9.0 | 20x10.5
Finish: Gloss Piano Black
Tires: Michelin Pilot Super Sport 245/35/20 | 285/30/20
Other: Rotary Forged | OE TPMS Compatible | Custom Offsets available
Weight range would be OK. Better would be a calculator that shows the weight for any given custom setup. Even if you can't get all the info you need from the manufacturers to do the calculation, maybe you could use some typical sizes and extrapolate, or at least show the closest wheel offset that you know the weight of.well, with custom wheels like the Forgestar with a high range of offsets, we can at best put a range of weights.
For example... the Avant Garde M621 at 19X9.5 +15 with no bolt pattern drilled weighs almost 24lbs but when cut for a Tesla Model 3 for 19X9.5 +38, it weighed in at 22lbs.
What tire/wheel size combo is on the adv?Here's 2 of many we've done so far!
