looks sideways at SR+ in the driveway with a 200mile round trip coming up.. Not necessarily expecting to manage without a charge and have a few options on the way back, but kinda hoped it might have been doable.
It probably is doable...but at what speed/time cost? That's what I've learned with this car. You have to make decisions on what time/speed is acceptable for long journeys and make your charging stops around that, which is why ABRP is really good at helping you decide.
looks sideways at SR+ in the driveway with a 200mile round trip coming up.. Not necessarily expecting to manage without a charge and have a few options on the way back, but kinda hoped it might have been doable..
This. Abrp is super important to the EV world, lets you see real world performance and permutations of weather etc.Give www.abetterrouteplanner.com a go and make sure you put in the relevant adjustments for climate/other conditions, temp, rain, wind, load etc,. I just leave mine set on a pessimistic setting to hopefully cover all eventualities.
Good point! A 20mph head wind makes the car work like you are doing 90. And we know that is bad for the range.A big factor is wind. Been a lot of it the last few days in the UK. A 15-20mph headwind can have a massive effect on your range. Couple of times on my regular Cardiff-Newcastle drive a strong Northerly wind has meant my range wasn't as the trip computer predicted and used a lot more juice than it thought. Similarly, a tailwind like that will make you go quite a bit further. But you need to realise the 300+ mile range is in perfect conditions with mixed speed driving, not cold wet windy 70mph.
yeah I'm just going to try autopilot at 70 and see what happens. Will definitely do the outbound in one go, and might need to stop around membury/reading on the way back so I'll keep an eye out. Will be on my own in the car so I can experiement a little without annoying the family as I get used to things
@Acko1985 - where did the 269 come from? Trip computer for the trip, or the energy graph? Energy graph will only show last 30 miles, and tbh I never remember to set up a trip counter...All these discussions about head wind etc are interesting, but the fact remains that OP went from 96% to 7%, apparently at 269 Wh/mile and covered 200 miles. 200 x 269 = 53.8 kWh. That is a lot less than 75kWh - so something is missing. Either the battery is way down on its capacity or there’s been some energy lost not accounted for in the 269 figure.
It’s not normally necessary to set up a trip computer if you have done any charging before departure. One of the trip cards gives you distance, kWh and kWh/mi since last charge.@Acko1985 - where did the 269 come from? Trip computer for the trip, or the energy graph? Energy graph will only show last 30 miles, and tbh I never remember to set up a trip counter...
Is there a way to adjust stops on ABRP? sometimes doing a windsor-bath round trip it’ll say to top up at members for 7 minutes on the way out, sometimes the way back. It’d be good to have more flexibility to tweak after the initial route to charge earlier/later. Zap map seems a bit better for that but still fiddly
You can add waypoints as you like and tweak the waypoint actions and parameters.
Click on the stop and change the time or kW to what you wantright but then it calculates charging stops for you - its those I’d like to tweak to see the effects. Eg doing an M4 run should I stop at wokingham, reading, membury, bristol and what differences for each?
edit: hmm zap map seems decent for that. You can tap chargers along the route and it’ll show the estimated charge level remaining at each one.
