Harbor Freight sells many different models of floor jack at different price points. The problem with all of the imported floor jacks is that you can't repair/rebuild the piston mechanism when the time comes.I just purchased a small shop jack. 33 lbs, aluminum. Fits very nicely in the deep rear well. Overkill, for sure, but better than a jack collapsing under a 4500lb. car.
(My fear of scissor jacks, though, is probably very outdated, going back to OEM jacks in the 1980s. Pure garbage.)
1.5 Ton Aluminum Rapid Pump® Racing Floor Jack
1.5 Ton Aluminum Racing Floor Jack with RapidPump®www.googleadservices.com
the modern spare only has one size for MY. They it works with all wheels. I'll have to think about this brake drag stuff.Sounds like EV Dave had the wrong diameter wheel/tire combination, causing the issue.
Dave says in the comments that that is what he should have done.What happens if you disable traction control while driving on the Modern spare?
Then there should be no issue with driving the Model Y using the Modern spare if you remember to turn off the Traction Control.Dave says in the comments that that is what he should have done.
so how do you turn off traction control? Just the off road assist? Or slip control? Both? Something else?Then there should be no issue with driving the Model Y using the Modern spare if you remember to turn off the Traction Control.
