Aodhan AFF7 Foreged Wheels on Model 3
Totally. I think they’re being a little conservative with the camber numbers because I’m using 18x10.5 +25 -2.2 degrees on grey brakes without rubbing but as you pointed out, it’s dependent on tire choice, rotor thickness, camber setup.
If all you care about is looks, why waste money on wider wheels/tires? Just get 15/20mm spacer-adapters and call it good.
Already did this, and I’m not a fan of the 19’s. I like the 18 aero’s (no caps of course) but these 19’s aren’t what I’m going for I.E why I’m looking for a set of aftermarket wheels.
I’m lowered on H&R’s and minimal camber.
Reactions: E.Potter
I turned my previous autocross wheels into street wheels so here’s the new setup.
19x9.5 +35 255/40R19 3mm front spacer, 8mm rear spacer. -2.9 front camber, -2.2 rear camber. MPP front rotors, M3P rear rotors. Definitely not as aggressive as my 10.5 width +25 but that’s what I wanted for daily.
Reactions: Daekwan
Digging this setup, thinking about running 19x8.5 on a M3P.
If I may ask, are you running spacers? stock suspension? Tire size?
Sure, I am not running spacers as these are 19x8.5 +35. I didn't want too aggressive of a look and wanted to keep the splashing to a minimum as I do live in the Pacific Northwest (rains a lot). The tires are PSAS4 245/40/19. I wanted to go a little bigger for a tad more comfort and not stretch the tires too much. I thought the 235 on 8.5 was a bit stretched. I have accounted for the large diameter in the increase in wh/m as well.
