aerodyne
2 of 3 EV's - Defect Free!
Thanks for more insight.
I knew the 12V being weak can cause more vampire drain but did not consider a bad contactor causing this issue. I suppose a bad contactor would close/open frequently at will?
Knowing now what you are describing, I think I might have the solution since my pack is scheduled for replacement ( see Wiki - Sudden Loss Of Range With 2019.16.x Software ) and that would hopefully fix any contactor issue. While the pack is being replaced, I was planning to ask them to check my 12V battery as well. So, in my case, it looks like both culprits you had mentioned will be out of the picture.
Yes, the failing contactors we're opening and closing frequently, that made me check SMT where I noticed low 12v. I had just replaced the 12v recently.
May your new pack charge fast, and have a long life...
