So far, everything that has been working, is still working. On that note, everything that has not been working is still not working. Push-to-talk still lags and times out the first time you press the button. Bluetooth calls still require a quick slide of the volume button to get audio to come through, although I will say that since .24, I've had quite a few occasions where I haven't had to do that, so who knows, maybe it's becoming self aware and will fix itself eventually
Some people have reported poor A2DP performance with Bluetooth. I use the built in Slacker radio, so I haven't tested it yet. I do know there is significant Bluetooth lag though (watching Netflix on iPad but playing audio over Bluetooth results in about a 1 second lag). I haven't tested to see if that's improved, but knowing what causes this, I highly doubt it's fixed.
Chess works, however the fact that it beat me in about 12 moves doesn't mean it's good... I'm just that bad
I have confirmed that the bug that
@ckoval7 found is reproducible. Basically, if you use easy entry, when you exit the arcade, it activates easy entry and moves your seat/steering wheel to the easy entry position.
Didn't test the changes to dog mode. I don't have a pet that's allowed in the car.
It
feels like AP's lane keep corrections are a lot smoother. After .24, the car felt like a bowling ball going down a lane with bumper rails up.
Will do a range/consumption check tomorrow as well as a vampire test tonight. I drove the car home on max battery power, so it used a bit more battery than usual.
Car still puts a smile on my face every day.
Let me know if there's something you want me to test/validate before you run the update. I have the scan tool/cable and ScanMyTesla as well as a dragy.
