i am surprised tesla doesn't allow my iPhone or iPod to plug into the USB port and stream music. I know I can through Bluetooth but most new car allow a plug and play?
Absolutely agree USB stick is the way to go with your tunes. iOS integration for your phone calls, contacts is there. Calendar is only 2 days deep.For all you audio geeks out there, the Tesla media player will play High Resolution audio files from a USB stick. It can play 24-bit/192kHz and 24-bit/96kHz FLAC files. It can also play AIFF and WAV as well. I'd recommend trying out some hd audio on your Model S or X. With really good source material, the sound systems can be quite nice.
Also if you have a Model X, I have done some initial tests on my X with pink noise and a frequency analyzer. I have the 6 seat configuration and the initial readings were taken with just a driver in the car and the mythical rear parcel shelf cover and rear lift gate privacy cover in place. I'll take some readings without the real park shelf cover in place and see if it changes the EQ settings.
I'll post more detailed info when I get a chance, but here is a suggested setting on the EQ controls that produces a frequency response that I enjoy. This is with the Volume level set to the first '5' level (one click above '4').
Low - 1.5
Mid - 6.0
High - 5
I didn't play around with that, I just set everything at the default center position.How about fade and balance? @Blurry_Eyed
Great stuff! Thanks neighbor!For all you audio geeks out there, the Tesla media player will play High Resolution audio files from a USB stick. It can play 24-bit/192kHz and 24-bit/96kHz FLAC files. It can also play AIFF and WAV as well. I'd recommend trying out some hd audio on your Model S or X. With really good source material, the sound systems can be quite nice.
Low - 1.5
Mid - 6.0
High - 5
Wait. It will play AIFF? Are you sure? All research I've done in the S threads say it will not play AIFF. I have just spent hours converting a bunch of my AIFF to FLAC and would appreciate not having to do more converting. Maybe I'll just load some and try for myself.For all you audio geeks out there, the Tesla media player will play High Resolution audio files from a USB stick. It can play 24-bit/192kHz and 24-bit/96kHz FLAC files. It can also play AIFF and WAV as well. I'd recommend trying out some hd audio on your Model S or X. With really good source material, the sound systems can be quite nice.
Low - 1.5
Mid - 6.0
High - 5
Sorry I didn't see your question above until now. You already figured it out. Yes, AIFF does play! I will be doing more audio tests and get some recommend EQ settings out, but just haven't had the time to set up the computer and measurement mic in the X recently.Confirmed. AIFF does play.
Well, damn that's a few hours I won't get back. At least I'll have a little extra room on my USB for future music purchases!
Thanks! Appreciate the audio testing. I'm already using your settings posted above. Although I did boost the bass by .5 and might go a bit higher. Yeah, I'm a sucker for the bass! Gotta rock the Beastie's!Sorry I didn't see your question above until now. You already figured it out. Yes, AIFF does play! I will be doing more audio tests and get some recommend EQ settings out, but just haven't had the time to set up the computer and measurement mic in the X recently.
My wife asked me to take out the rear parcel shelf, so the next EQ settings will be with out the shelf in place and with the two back row seats in the up position. May not be able to do this for another week or two, but I will get something done in the future for everyone to use!
I'm doing these first set of calibrations with fade and balance set to '0' for now.How about fade and balance? @Blurry_Eyed
These are meant as a starting reference. Also these were made with dolby surround off, fade and balance set to zero
Thanks for adding the detail, I should have pointed that I do have the Ultra High Fidelity Sound upgrade. My settings are probably not valid for the standard audio package.For new readers you have a configuration with the audio upgrade (HFSA) that gets you the subwoofer and extra speakers.
