paulp
Couldn’t agree moreEach to their own I say
I think they have just changed the regen curve, I notice it most at the end of the braking curve. Up I until yesterday I would never need the brake to get it to a full stop on the speed I was driving at an intersection. Now I’m having to apply brake right at the end. For the last 10-15kph sort of thingSo paid a bit more attention to regen on the drive this morning and really wasn't able to tell the difference particularly at the end of the ramp.
I've had. 6 for a while though and tend to start regen early and feather it in as required so it's possible I just adapted to it without noticing.
I really suspect if they changed anything that they may have slightly changed the ramp that takes effect.
Tesla app works well on all those phones except for the uwb which is yet to arrive in the android app. I tried in many different versions from android 9 all the way to my latest s24ultra with android 14. All worked flawlessly. So nothing to be afraid of for nothing or oneplus.Im looking into divorcing myself from my long term Apple relationship.
Considering something like the Nothing Phone 2 or the OnePlus 12
Does anyone here have one of these phones who can comment on Tesla App compatibility?
Thanks mateTesla app works well on all those phones except for the uwb which is yet to arrive in the android app. I tried in many different versions from android 9 all the way to my latest s24ultra with android 14. All worked flawlessly. So nothing to be afraid of for nothing or oneplus.
when I was approached on my S about 8 years ago I challenged them to a drag race…they declined. Probably knew they would lose.Just got approached while picking up dinner by a couple of cops.
They looked at the car and one said “that looks awesome..” i did the only thing appropriate and entertained them with the fart noises.
You would easily today too. I think they are in kia sorrentos or something hahawhen I was approached on my S about 8 years ago I challenged them to a drag race…they declined. Probably knew they would lose.
I don't think you'll do any damage since you'll still doing the calibration later at night.On a slower charger this calibration time takes quite a few minuites. Is there any harm in disconnecting while it says calibrating or should you leave it connected at all costs? In my case calibration is done later at night while plugged in.
What is the process to get the controller connected? I can seem to pair it but not connect it? I’m also getting the pro controller coming up and another random Bluetooth device with a serial numberHaven't got a highland to try on but I've used the cheap kmart switch gaming controller with my model Y and it works. Easy enough to try out yourself and if they don't work then take them back for a refund.
Thanks for this, I tried home and + but didn't see the controller, then tried home and A (and home and X) and got it registered as a 'Gamepad' but then it never leaves pairing mode (flashing lights) so doesn't seem to properly pair. Might be something I am doing wrong or maybe it no longer worksI can't remember which mode I needed to use but try one of these. I think it was the Home and + button
Ok I just tried and disconnected my controller.Thanks for this, I tried home and + but didn't see the controller, then tried home and A (and home and X) and got it registered as a 'Gamepad' but then it never leaves pairing mode (flashing lights) so doesn't seem to properly pair. Might be something I am doing wrong or maybe it no longer works
I don't think there is any issue in stopping charge at any time of the charging process. The thing that happens during calibration at the end of full charge is that it will slowly trickle charge and monitor the voltage. Let's say 420v is the max pack voltage. So when it reaches almost 410v it periodically stops the charging and wait and then check voltage if the voltage stays at the levels just before stopping the charge, then it resumes charging and repeat the process until the Battery voltage can no longer go up and record that as the Max SoC.random question:
When charging on a slow charger (<25kw) obviously the charge rate slows right down towards the end. The car gets to 99% as indicated on the screen and charging app. The car then goes to 'calibrating' and the charging app stays on 99% and indicates power is still being drawn until charging finishes at 100%.
FWIW after disconnecting the the car indicates 100%.
Just curious....
Ok gave that a shot and same issue. I did notice a nano second of a frame which looked like an error so I filmed it in slow mo and grabbed this frame. Looks like it might be a no goOk I just tried and disconnected my controller.
Hold down the home + x button to put it in pair mode. I was then able to connect it to the car.
If the pairing mode flashes try holding down the home button which should stop the flashing and try again
If there is no warning in the manual then I would not be concerned.random question:
Just curious....
It was all a bit of a storm in a teacup huh.After driving the loaner previous gen model 3 a couple days ago, it made me feel so glad I went for the highland. So much more refinement, quality, luxury fit and finish.
Oh and now that I'm used to the buttons and screen, I hated the stalks Hah!
