Yes. It was ON. I actually turned OFF and then ON. It still didn’t work.Did you double check the lane change option is still set to on? It gets turned off sometimes.
Yes. I was in middle lane and EAP was engaged.Were you on a multi-lane highway that was recognized by AP? You should see the adjacent lanes available in the IC.
Instrument cluster showed solid blue lines.And were the gray lane lines for the adjacent lanes showing on your instrument cluster display?
Yes I had those as wellThats good, but there should be another set of grey lines outlining the adjacent lanes as well if auto lane change is going to work. See attached photo.View attachment 256754
I used 2017.42 for the first time today and Auto Lane Change worked fine, I used it multiple times.Updated to 42.1 last Saturday and just noticed that Auto Lane change is not working in EAP mode. I put my blinker on right or left and the car stays in lane and doesn’t change. I have MS 75D.
Anyone else notice this?
The manual suggests that the driver must be holding the steering before and during the lane change. I suspect this build has become stricter in that regard and disregarding your indicator command. If this i is indeed the case it would be nice if the software immediately issued a ‘hold steering’ alter.
17.42.1 is AP2.5 only. No feature changes (theoretically) except it doesn’t bork your car.I used 2017.42 for the first time today and Auto Lane Change worked fine, I used it multiple times.
I was not aware there was a “42.1” version.
Never noticed that. Thank you.Thats good, but there should be another set of grey lines outlining the adjacent lanes as well if auto lane change is going to work
I feel you... having your car work at all may, in fact, be a feature.I don’t know, some might call that a feature
