Lindenwood
Refined camber to 3.2F and 2.3r and re-zeroed toe.The bar has been on for months, since before my last road course track day. At that’s event, I let two instructors drive my car and both remarked specifically at its balance, predictability, and overall lateral grip. I even asked if they had any recommendations to suspension changes that would help reduce the instability under high-speed braking, and the only think they recommended was maybe stiffer bushings / bearings, or aero if I wanted to get real hardcore (hence my wing).
The only change I have made in 8 months was the FLCABs about 6 months ago (and I could feel the positive benefits), and now last weekend’s swap to the sport set. Perhaps it is a bit over-sprung in the rear with both the sport coils and stiffer rear bar, but I am reticent to blame the bar entirely.
Just verified Toe is 0/0, but camber did go up a bit in the rear.
Front: 3.2 & 3.4
Rear: 2.3 & 2.6
I set my tire pressures from 42 to 36 as well. Upon reflection it occurred to me that the sport kit might need a bit lower pressures since the heavier coils can’t move against the smaller bumps quite as well.
I also installed the compression rod bearings while I was in there!
